2008 G6 New Problem!!! - Pontiac G6 Forum
post #1 of 23 (permalink) Old 02-15-2012, 04:09 AM Thread Starter
I have encountered a new issue with my 2008 G6 4 cylinder. I bought the car new and it has 29,990 on it. What just started up now, and it's happened twice already, is that when you are going 30 MPH and giving it the gas to take the car up to 40 or more that very last shift the car makes it now slows the engine down or surges it. It almost feels like it's running out of gas. Then, within a minute, it slowly picks up speed again but then hesitates a bit after that. I'll take it to the dealer but I wanted to ask you guy's first. Anyone else with this problem? Thanks! Don
doning is offline
post #2 of 23 (permalink) Old 02-15-2012, 02:37 PM
Before you take it to the dealer: Is the check engine lamp on? If not, you should still check for pending codes (Autozone can do this free). Hesitation on acceleration can be caused by a lot of things. If there are no codes, & the dealer can't easily replicate the issue in a short test drive, they'll probably just shoo you out the door.
It could be as simple as a dirty MAF sensor or throttle body.
post #3 of 23 (permalink) Old 02-15-2012, 04:37 PM
I was thinking you should try cleaning the TB or MAF if you have no check engine light.
post #4 of 23 (permalink) Old 02-15-2012, 08:13 PM
Dr_G6's Avatar
My car does something like this and I, too, have an 08 4cyl. The other day on the highway going about 50mph, I switched to the fast lane to try and accelerate past a slower moving car and it literally took a good 5-8 seconds for the car to gain ANY type of speed. It's almost like the engine refused to respond at all, despite the fact that the gas pedal was being pushed pretty close to the floor. When I first noticed this problem months ago, took it to the dealer and they hooked it up to the machine, a tech drove it, and they could find no problems w/the transmission. No codes are being thrown so of course that complicates the matter too. I'm at about to 58.6K miles and I was wondering if changing the transmission fluid would be of any help with this problem. Suggestions?
08 G6 Value Leader
STOCK and boring....for now
Dr_G6 is offline
post #5 of 23 (permalink) Old 02-15-2012, 08:23 PM
Tranny fluid--No.
You should also start with cleaning the MAF sensor & TB. These are routine maintenance items on all modern cars though I realize they don't tell you that in the owner's manual.
Be careful with the MAF sensor. The only thing that should touch it is MAF sensor cleaning spray.
post #6 of 23 (permalink) Old 02-16-2012, 03:58 AM Thread Starter
No. I have no check engine lights. I was thinking maybe disconnecting the battery and reconnecting to reset something?
doning is offline
post #7 of 23 (permalink) Old 02-17-2012, 02:25 AM
2006 G6 GTP
Might be a torque converter or a 3rd gear apply piston in the trans...
Does the car switch back and forth from "overdrive"? Does it jerk forward when doing a rolling stop?
FreakaLeak69 is offline
post #8 of 23 (permalink) Old 02-17-2012, 04:02 AM Thread Starter
No it does not.
doning is offline
post #9 of 23 (permalink) Old 02-17-2012, 09:23 AM
2006 G6 GTP
Well that's good! lol.
Have you checked the fuel pump? Sometimes a sporatic fuel pump can cause really weird issues like this...being that u have no pcm codes. I had a Ranger that the fuel pump was going out. It would build up extreme pressure on initial start up and bog down like this on WOT or even accelerating up a hill because it couldn't keep a steady flow of gas to the injectors. Come to think of it...I never once had a pcm code or check engine light either.
post #10 of 23 (permalink) Old 02-17-2012, 01:11 PM
Pending codes will not light the CEL so you should still check for codes. You can get a basic code reader for under 25 bucks now. If you disconnect the battery you'll lose all code info that might help in the diagnosis. It is always worth doing.
post #11 of 23 (permalink) Old 02-18-2012, 12:40 AM
2006 G6 GTP
Yup
True...I agree, Greenman. It does help most of the time to check the pcm codes for sure before replacing anything.
post #12 of 23 (permalink) Old 02-19-2012, 09:19 AM
G6 GT member
I HATE "overdrive"
(MPH)>97,98,99,100,.....101.....102.....103.....10 4.....105
Can you turn it off to do an experiment to see if that's the problem......for the guy having the problem, of course!!!
killjoydod is offline
post #13 of 23 (permalink) Old 02-20-2012, 12:18 AM
2006 G6 GTP
LOL. Overdrive actually means that your torque converter locks in place, running 1:1 with the engine and trans. Most people think it's a gear by itself. It can be turned off with a tech scanner or a wired up switch, but u would get HORRIBLE gas mileage in 3rd and 4th gear.
post #14 of 23 (permalink) Old 02-24-2012, 02:54 AM Thread Starter
Well, today's the day. I'm having my wife take the G6 to the dealer. I made the service manager a nice list. We'll see how far I get with that!
doning is offline
post #15 of 23 (permalink) Old 02-25-2012, 12:02 AM
Gpof59
Sounds like a bad throttle position sensor.
pof09G6 is offline
Looking at a 2008 G6 kjvanek G6 Buyer's Guide/General Information 2 04-24-2011 08:25 PM
Problem with trunk on 2008 G6 convertible nerd1701 Problems and Solutions 6 03-31-2011 10:26 AM
2008 G6-V6 with shutter problem... Maliki2 Problems and Solutions 3 02-01-2010 03:08 PM
2008 gxp g6 3.6 transammatt Problems and Solutions 7 02-11-2008 08:00 PM
2008 G6-gxp RayZ Auto News and Rumors 13 01-30-2008 07:53 AM
