2010 engine skips under load - Pontiac G6 Forum
post #1 of 4 (permalink) Old 02-19-2012, 10:07 AM Thread Starter
Hey guys/gals I am new on the forum. My wife drives a 2010 G6 GT with the 3.5L V6, 4 door. I have been a Pontiac fanatic as I have owned about 4 Trans Am's, own a 2000 WS6 currently with a LS6 I built for it pushing around 480hp to the tires and 454 tq as well. So on that note I understand how engines work and I understand sensors can be a nightmare. The problem I have with the G6 is when I drive it under normal acceleration between 1500-2000 rpm it skips and jumps around the rpm range until it reaches anything over 3k then it clears up for the most part. I thought maybe the injectors could have been clogged from bad gas or something but I have run Sea Foam at full strength a few times because I it seems to be the best I know about when it comes to cleaning out fuel systems. Anyway has anyone had an issue with their 2010 similar to this? I have not checked the plugs yet but I wouldn't think with 32k miles on the car they would be bad. Thanks in advance for the help. I use LS1TECH for my TA's tech issues so I hope this forum can do the same for the G6 =)
platinum ws6 is offline
post #2 of 4 (permalink) Old 02-19-2012, 12:13 PM
Varsity Squad
CalsGTP's Avatar
Any stored codes? Even if check engine light is not on there could be codes. Start there. There are so many things that could be causing this hick-up. I am currently dealing with one caused by the electronic throttle body.
CalsGTP is offline
post #3 of 4 (permalink) Old 02-19-2012, 03:19 PM Thread Starter
I was unaware it could be throwing codes without actually setting off the SES light. I will start there I guess, thanks.
2000 Trans Am WS6: Sebring Silver Metallic LS6, TEA 5.3 stg. 2 heads, VRx5 cam, Monster stg 3 clutch, 3.73 gears, yada yada.....too much more to list.
Daily Driver- 2003 Silverado Z71, 3 inch body lift, 35s, Hypertech
Wife's: 2010 G6 Silver Metallic 3.5 V6 with ebony int.
post #4 of 4 (permalink) Old 06-13-2012, 06:36 AM Thread Starter
I have checked everything I can think of, even decided to bite the bullet and take it to the stealership to check for any stored codes but all I found was less money in my wallet. Has anyone else had any issues like this? It specifically jumps rpms between 1500 and 2000 rpm while accelerating at a normal pace. It is my wifes car and I don't drive it every day but when I do it drives me insane! Any ideas would be very helpful, thanks.
I'm looking to buy a 2010 G6 & need help reginaalear G6 Buyer's Guide/General Information 6 02-06-2011 04:53 PM
CDs won't load piratejeffwdw Car Audio, Video and Security 5 11-08-2010 11:17 AM
Check Engine/Scv Vehicle Soon/Reduced Engine Pwr Indicators all on? insiminator Problems and Solutions 7 09-19-2010 08:21 AM
HIN-NOPI 2010 SUPERSHOW SOLDIER FIELD, CHICAGO ILLINOIS September 25, 2010 mcwheels Off-Topics 0 09-15-2010 10:05 AM
HIN-NOPI 2010 SUPERSHOW LOS ANGELES CONVENTION CENTER September 18, 2010 mcwheels The West 0 08-20-2010 08:18 AM
