2006 G6 4cyl / Acceleration Issues.... Please Help! - Pontiac G6 Forum
post #1 of 7 (permalink) Old 03-05-2012, 09:20 AM Thread Starter
I'm having some accelerating issues with my daughters 06' 4 banger. I replaced the upstream O2 sensor and the Mass Air Flow Sensor, based on the CEL codes and the car just won't Go?!? It does, like, 25mph Max? Anyone with Some Positive Feedback, other that taking it to a "Dealership", Your In Site and Experience would be GREATLY Appreciated!
rockerman2000 is offline
post #2 of 7 (permalink) Old 03-05-2012, 11:20 AM
do you know what codes came up?
post #3 of 7 (permalink) Old 03-05-2012, 05:26 PM
Pull the codes again and post what you get. It could be something Throttle Body related, or Gas pedal related. It seems to usually be the Throttle Body more of the time when issues like this come up.
post #4 of 7 (permalink) Old 03-06-2012, 09:27 AM
Check cat. converter for plugging.
post #5 of 7 (permalink) Old 03-06-2012, 02:46 PM Thread Starter
Thanks To All Who Have Replied With Info..... The CEL codes that came up were:
1) For the upstream O2 sensor, which I have replaced.
2) For the MAF sensor, which I have also replaced.
3) P0300, which is a random misfire code.
I cleared the codes after replacing the sensors and they haven't come back up, save for the P0300 code, that has come back on as the motor gags to a halt.
What the engine is specifically doing, is.... when you start the car, it runs and idles with only a slight hesitation, but when you give it some juice, it gags and seems as though it's not getting enough fuel. IDK?
I removed the throttle body and cleaned it up, checked the plugs and the coil packs, checked the wiring for any shorts, made sure the fuel pump was feeding fuel to the injection rail.
But, I'm beginning to agree with the poster who said, the cat converter may be stopped up.
How would I go about checking that? ...... Anybody???
post #6 of 7 (permalink) Old 03-06-2012, 04:06 PM
An exhaust back pressure test would be definitive of a clogged cat. I'm sure you can find it on youtube.
post #7 of 7 (permalink) Old 03-07-2012, 09:09 AM
The check can also be done with a vacuum gauge.
2006 G6 Steering Issues Vita Steering Lockup Issues & Discussion 45 09-26-2012 10:53 AM
Issues with Acceleration? nick125 Problems and Solutions 6 05-31-2011 01:42 PM
2008 Pontiac G6 having acceleration issues Baltimore_Pontiac Problems and Solutions 1 11-27-2010 08:11 PM
2006 G6 Overheating issues and loosing coolent. Help...possible headgaskets? water pu 2006PontiacG6 Problems and Solutions 22 08-06-2009 10:59 PM
2.0 turbo from hhr ss into 4cyl g6 wtaylor2007 Powertrain Performance Modifications 0 02-24-2008 03:51 PM
