05' G6 V6 Likes to Embarrass Me... - Pontiac G6 Forum
post #1 of 10 (permalink) Old 03-12-2012, 08:41 AM Thread Starter
About twice a week i'll try to turn the car over and i'll get a wer wer wer wer wer wer wer then nothing. After that if I try to turn the car over without giving it a little gas ill get the same thing (almost killed the battery trying to get it to start on its own). But if I tap the gas a little it will start up just fine. Im not completely sure but I think iv'e noticed it occurring the most just after getting gas or when there's a bunch of people around typically a group of girls (I know the latter doesn't make sense from a mechanical prospective but I swear it does). Any way, normally it turns over just fine but when I get that initial fail it will just fail until the battery is dead or I tap the gas on start-up. After I tap the gas to start it I can turn the car right off and turn it over like normal and it will work no problem again.......any ideas?????
07BBeck is offline
post #2 of 10 (permalink) Old 03-12-2012, 09:39 AM
reverttheclown's Avatar
you should seclude yourself to only hanging out with dudes! on a more serious note...everyone and their brother is going to tell you to clean your MAF sensor and throttle body, check your air filter and possibly run seafoam through the system so check all that out. check out that easy DIY stuff first and see what happens
2006 Pontiac G6 V6 3500L
Crimson Red
reverttheclown is offline
post #3 of 10 (permalink) Old 03-12-2012, 10:10 AM Thread Starter
What's the MAF sensor and where can I locate it?
07BBeck is offline
post #4 of 10 (permalink) Old 03-12-2012, 10:15 AM
mass air flow sensor...plugs into the intake tubing right after the air filter.
Crimson Red
post #5 of 10 (permalink) Old 03-12-2012, 10:20 AM Thread Starter
Cool thanks! Ill take a look at it today. Any suggestions on what to clean it with? Warm water? WD-40?
07BBeck is offline
post #6 of 10 (permalink) Old 03-12-2012, 10:54 AM
any electrical cleaner will do...i think they make cleaner specifically for MAF's check your local auto parts store. wd-40 is not a cleaning agent..
Crimson Red
post #7 of 10 (permalink) Old 03-12-2012, 12:04 PM
I would not recommend using anything but maf sensor cleaning spray. Do not touch the sensor with anything but the spray. They are not inexpensive if you ruin it.
First: checked it for codes? ALWAYS start by checking for codes. Report back with any found.
post #8 of 10 (permalink) Old 03-13-2012, 11:29 AM Thread Starter
I saw someone else say advanced auto or auto zone will do a codes check for free? or is that something else?
07BBeck is offline
post #9 of 10 (permalink) Old 03-13-2012, 12:29 PM
yes they will read codes for free
Crimson Red
post #10 of 10 (permalink) Old 03-13-2012, 12:44 PM
Or you can get your own basic code reader for around $20 now.
