2006 Hard Top isn't lifting - Pontiac G6 Forum
post #1 of 9 (permalink) Old 03-18-2012, 09:52 AM Thread Starter
Cool 2006 Hard Top isn't lifting
The trunk lid started giving us problems about a year ago . When it started to lift , it would get stuck and you would help lift it and then the motor/gear? would engage and the top would complete it's cycle. Now we're getting no lift at all .I can open the trunk and see all the mechanisms but I'm not sure what or where to check first . I'm an RV tech and handy with wrenches, meter , etc. I need some help troubleshooting this one . It's getting warm and we want to use the top .Please help me keep the wife happy. THANKS !!
VICKIG6 is offline
post #2 of 9 (permalink) Old 03-19-2012, 05:11 AM
Fried like a Cheese Stick
Droptop Diamond's Avatar
Just as a rough guess, hydraulic fluid?
09 White Diamond Tricoat 'vert here!
Now with CRABs, STBs, & The Heart Ruling The Mind!
Odd random pics on my facebook page http://www.facebook.com/profile.php?id=100001119651822
Droptop Diamond is offline
post #3 of 9 (permalink) Old 03-19-2012, 06:21 PM Thread Starter
G6 Top
It's electric
VICKIG6 is offline
post #4 of 9 (permalink) Old 04-08-2012, 05:01 PM
Glenn's Avatar
Sounds like you don't use your top much. One thing I that I found out, you have to keep it cleaned and lubed, every hing, every pivot point, if something gets gummed up, and does not move smoothly your going have problems. My top is down more than it up. Once a month I lube all the hings. Droptop Diamond is correct, the top is electrically activate, and hydraulically actuate. All those (looking little bicycle brake cables) are hydraulic lines. But if you can't get the top to start to open, would start with the switch first, replaced mine twice now. Try wiggling the switch while depressed. Still don't like where they put that switch. Hope this helps.
Glenn is offline
post #5 of 9 (permalink) Old 04-09-2012, 05:33 AM
x2 on where they put the switch
post #6 of 9 (permalink) Old 04-18-2012, 07:50 PM Thread Starter
Cool Stuck Top
I didn't realize the mechanism was electro hydraulic . I'm going to try the switch wiggle method to get it up . Then look for leaks . Then clean and lube the mechanisms. Recomended cleaner and lube ?Thanks for the help .
VICKIG6 is offline
post #7 of 9 (permalink) Old 05-01-2012, 05:39 PM Thread Starter
OK ..Found the reservoir . Its low . Know what kind of fluid it takes ?It's a blue color .
VICKIG6 is offline
post #8 of 9 (permalink) Old 05-05-2012, 02:08 PM Thread Starter
Hard Top Fluid Type
GM Electro Hydraulic Power Steering Fluid Part # 88901975. This number can be crossed to various different sythetic oils .Gonna go fill it now .
VICKIG6 is offline
post #9 of 9 (permalink) Old 05-06-2012, 06:43 AM
Power Steering Fluid? interesting....but I suppose it makes sense. Maybe.
Let us know how it works
Hard Shift? SippinSizzurp Problems and Solutions 1 08-31-2011 11:25 PM
?'s about carbon fiber - lifting and deteriorating? Dav3 G6 Buyer's Guide/General Information 1 05-25-2011 07:52 PM
ait body kit, how hard??? 2pimp4u Appearance Modifications and Lighting 10 03-17-2011 09:56 PM
Hard Starting/Hesitation/Rough Idle + More issue resloved also tech bulltein! Hard St mjgonegm Problems and Solutions 1 01-28-2011 03:26 PM
How hard do you rev your G6? G6~Mike G6 Buyer's Guide/General Information 28 01-07-2006 12:25 PM
