2008 g6 battery issue - Pontiac G6 Forum
post #1 of 8 (permalink) Old 04-16-2012, 04:07 PM Thread Starter
My 2008 4cyl. g6 in october was acting like the battery was dying, would barely turnover, it would by almost to the point of dying. I checked the battery it was 4 years old, so i just went ahead and put a new one in. It helped up until now (6 months later) and the same issue. It seems to my like it is the starter. I have checked the alternator with my voltmeter and it is working fine. I can drive it for a while and when i get back in it, it still drags almost down to nothing when it starts. Anybody has dealt with this before, it would sure be helpful, my gut tells me it is the starter??
Pontiacplus is offline
post #2 of 8 (permalink) Old 04-16-2012, 04:28 PM
Have you tested for a parasitic drain?
post #3 of 8 (permalink) Old 04-16-2012, 06:44 PM Thread Starter
I have good knowledge with a voltmeter, i will give it a try, let me know the easiest and best way you think. I figured driving it daily with the alternator working would eliminate a parasitic drain issue but even driving it does jot seem to help it start better
post #4 of 8 (permalink) Old 04-16-2012, 08:32 PM
Slow starter rotation could be caused by loose or corroded connections/cables between the battery, starter & engine ground, or the battery is drained. Could also be the starter but don't throw a starter at it until you've eliminated the other possibilities.
What is the voltage across the battery terminals with no load on it (everything is off)? This tells you the battery's relative charge condition. Don't assume the battery is good because its only 6 months old. Charge it up & have it load-tested to be sure.
So this condition is not intermittent?
Learning how to do a parasitic drain test is easy & very worthwhile due to how commonly parasitic drains develop. Eric's a great teacher:
post #5 of 8 (permalink) Old 04-17-2012, 07:56 AM Thread Starter
http://www.youtube.com/watch?v=KF1gijj03_0
http://www.youtube.com/watch?v=RKjdn...feature=relmfu
Thanks for this info.....I charged the battery with my good 2 amp charger all night last night and it is no better this morning. I charged it with the battery terminals/cables on, I wish I would of disconnected the car from the equation and just charged the battery. The battery says 12.89 volts with no load and it jumps up to 14.86 when it does start.
I will take the battery this afternoon to get it load tested, to eliminate that. Just wondering is the starter a common problem on the g6
post #6 of 8 (permalink) Old 04-17-2012, 04:21 PM
Not really. But you may have drawn the lucky straw.
What's the mileage?
Have you removed & cleaned all the connections?
post #7 of 8 (permalink) Old 04-17-2012, 09:43 PM Thread Starter
What's the mileage?
Got up under it today and had wife turn it over......whisps off smoke come out of the starter......checked connections and they are good......definitely starter, yes i got fortunate this time......i also noticed when starting it the headlights were not draining and that is usually a tell tale starter sign......Thanks for helping me and discussing it.....i already got the old one off and the other is on order $85 from o'reilys
post #8 of 8 (permalink) Old 04-19-2012, 03:27 PM
Make sure you clean the cable from the battery before reinstalling it on the new starter. Also using dielectric grease on the electrical contacting surfaces would help prevent corrosion (which limits the flow of current).
2008 G6 GT Hard Top convertible parts issue…. JoethepainPA73 Problems and Solutions 11 03-27-2017 10:41 AM
2008 pontiac g6 sedan headlights issue killajayy88 Problems and Solutions 15 02-08-2012 07:37 AM
Help!! Steering issue Not lockup issue baker44440ex Problems and Solutions 5 10-29-2011 10:09 AM
Battery/alternator issue Ladylove Problems and Solutions 1 06-28-2011 02:40 PM
battery issue G6R Problems and Solutions 6 01-26-2009 05:32 PM
