2008 g6 overheating losing coolant - Pontiac G6 Forum
post #1 of 4 (permalink) Old 07-17-2012, 07:42 AM Thread Starter
I have a 4 cylinders g6 and it has overheated twice and I can't figure out. Where I'm leaking coolant... its not in the oil but where is it going? Anyone else havethis problem?
fkracidfire is offline
post #2 of 4 (permalink) Old 07-17-2012, 08:31 AM
sounds like a head gasket......any fluid coming from exhaust?
post #3 of 4 (permalink) Old 07-17-2012, 01:05 PM
Internal: Any white smoke from the tailpipe?
Coolant dye & a black light (15 bucks total) will help find external leaks. Start looking at the coolant pump weep hole.
post #4 of 4 (permalink) Old 07-18-2012, 03:55 PM Thread Starter
no its not a head gasket... i just replaced that on my malibu.. that sucked... i put a new cap on the overflow container and havent had a problem yet, ill keep you u[pdated if it happens again but thanks for your help peeps
Losing Oil ninorc Problems and Solutions 7 01-19-2012 12:29 PM
Overheating 09 g6 gxp wyattgoose5150 Problems and Solutions 4 07-08-2011 11:13 AM
HELP, '09 G6 overheating, dealer says nothing wrong!! ms09g6 Problems and Solutions 2 08-04-2010 01:16 PM
Leaking coolant, coolant recovery tank cap. Dvin211 Problems and Solutions 5 05-20-2010 09:52 AM
Losing sleep IS IT HERE YET!!! Saclunch New Member Introductions 5 08-17-2008 08:46 AM
