2005 3.5L V6 G6 won't start - Pontiac G6 Forum
post #1 of 3 (permalink) Old 08-06-2012, 11:59 AM Thread Starter
Unhappy 2005 3.5L V6 G6 won't start
I have a 2005 pontiac g6 sedan. The other day I parked the car, quite hot outside, then when I went to start it, no go. It clicked like the battery was dead, but the entire electrical system was restarted, clock set to 1200, radio on, windows worked, lights worked, jumped it and it started. Drove it for 30 miles turned it off when I got home and restarted once, the second time I restarted it, just click again. Again I jumped it and it started. I let it run for a good hour then shut it off. While it was running I disconnected the positive cable and the car continued to run, im my mind eliminating alternator problem. This morning I went outside to start it, turned it to the on position, clock was still set properly, when I turned the ignition the clock reset itself and it wouldn't start. What could be causing this? Perhaps a new battery would help?
dani1327leah is offline
post #2 of 3 (permalink) Old 08-06-2012, 01:42 PM
Have your battery load tested wherever batteries are sold. If it is a Delco (OEM), just replace it.
post #3 of 3 (permalink) Old 08-11-2012, 08:14 AM
and what if it a 6 mo old battery
05 G6
ipad mini install
Gametag psn=getonerd 360=geronerd
getonerd is offline
2005 G6 Stalled in Water will not start michellin7 Problems and Solutions 12 06-03-2016 06:37 AM
2005 G6 Wont Start crashnburn54 Problems and Solutions 1 01-04-2012 04:57 PM
2005 G6 won't start.... adam3143 Problems and Solutions 2 06-08-2011 10:08 AM
2005 Pontiac G6 won't start with warm engine baltimoreG6 Problems and Solutions 6 01-13-2009 05:43 AM
