P0010 Code/Solution - Page 2 - Pontiac G6 Forum
post #16 of 19 (permalink) Old 03-15-2016, 10:19 AM
I just had the P0010 code come up, check engine light was on as well as the traction control light. I replaced the intake solenoid but when I drive my car the engine "hops" or"chugs" not sure what the problem is. Any ideas?
Torianacasey is offline
post #17 of 19 (permalink) Old 05-03-2016, 08:58 AM
How do you tell which camshaft sensor is bad on 09 four cylinder g6
Stubej is offline
post #18 of 19 (permalink) Old 05-03-2016, 12:12 PM
Best to replace both. Or OHM it out, also check the screen for debris.
09 G6 2.4 Sun & sound package-Preferred package
225/50R17S factory
post #19 of 19 (permalink) Old 05-04-2017, 10:56 AM
I am having same issue with my daughters car right now but mechanic says he has already changed those 2. And still giving me those codes.
andjen is offline
Check Engine Light P0010 & P0011 AllanR Problems and Solutions 3 04-14-2012 12:55 PM
p0011/p0010 and Hard Shifting ?????? Resin8or Problems and Solutions 15 10-04-2011 02:05 PM
have solution for brake lights grim reaper g6 Problems and Solutions 3 08-29-2011 11:52 AM
Hard shifting issue. Solution mkotrba2 Problems and Solutions 0 07-01-2009 11:44 AM
Steering Solution ??? doubleimage22 Steering Lockup Issues & Discussion 7 02-01-2008 09:52 PM
