2005 G6 GT dies on start up unless I push down gas pedal! - Pontiac G6 Forum
post #1 of 16 (permalink) Old 10-01-2014, 01:38 AM Thread Starter
Red face 2005 G6 GT dies on start up unless I push down gas pedal!
Hey guys, I am new to to the Pontiac world! So, here's my first issue I have run into with my new-ish baby! :/
About 95% of the time, when I go to start up my car, it'll turn over, start to run, but dies almost immediately after unless I give it plenty of gas! I have no check engine light on, nor is little wrench light on, (which seems odd because it seems these cars are very sensitive & alert you to the slightest issue!) I've racked my brain trying to figure out what it could be, Googled my heart out and have come up with no solution or answer to my problem! It's so embarrassing when A.) It dies, or B.) I sound like I'm trying to intimidate/race the old lady loading her groceries into her car next to me in a parking lot. Any help/suggestions and or possible resolution to this issue would be simply amazing and very much appreciated!!! Thanks in advance!
brittanyann0318 is offline
post #2 of 16 (permalink) Old 10-01-2014, 07:38 AM
Welcome!
I know that a dirty throttle body gives our cars a hard time starting, so you may want to start with having that and your Mass Airflow Sensor cleaned.
post #3 of 16 (permalink) Old 10-01-2014, 01:42 PM
I would suggest a code scan regardless of the check engine light. There are temporary codes that may be indicative of the source of the problem
boomer is offline
post #4 of 16 (permalink) Old 11-08-2014, 08:21 PM
I am having a similar problem. The car starts fine but after I drive about 3 blocks and stop at an intersection it will either die or the engine bogs down and there is a significant power loss from motor. I cant figure out what the problem is. I joined this site in hopes to find a solution.
dhart62 is offline
post #5 of 16 (permalink) Old 11-10-2014, 03:33 PM Thread Starter
Yeah, mine is just when I try to start it, it never bogs out at a stop. We cleaned my injectors, and throttle body. We did some research on other sites and think it may actually be the fuel pressure regulator. I havery read that that this is I really common problem with the 05 G6! Ordered the part, will update if it fixes the issue!
post #6 of 16 (permalink) Old 11-10-2014, 03:38 PM Thread Starter
I know this is common sense, & totally not being rude or anything but- have you tried changing your spark plugs? Does it do it any other time when accelerating quickly? Mine was missing really badly when I first got it, so we figured we'd do a tune up, and that problem went away. When it bogs out, do you smell anything odd?
post #7 of 16 (permalink) Old 11-10-2014, 04:02 PM
pressure regulation is a function of the fuel pump on all returnless systems. there is no separate regulator. have u checked fuel rail pressure at startup?
post #8 of 16 (permalink) Old 11-11-2014, 12:22 PM Thread Starter
No, not yet. My boyfriend works too much (lol) and we haven't had a shop to use for light since it's so dark by the time he's gotten home. I will have him check that this weekend- I just want my car to start normally again!
post #9 of 16 (permalink) Old 11-11-2014, 12:23 PM Thread Starter
I'm confused, I ordered a "fuel pressure regulator" from o"reilleys, so my car must have one I'm assuming?
post #10 of 16 (permalink) Old 11-11-2014, 01:36 PM
i guarantee u that clerk is confusing the fuel tank pressure sensor with a fuel line pressure sensor. a new tank pressure sensor won't help you.
checking the fuel pressure at the fuel rail would be my first step. there's a how-to in the chiltons for g6 book. pressure should be 50-60psi.
post #11 of 16 (permalink) Old 01-08-2015, 06:48 PM
V.McCall
2005 G6 GT - rattly situation when starting sometimes
For a couple of years now, only sometimes, when I try to start my car, it does a rattly thing & won't catch. If I pump accelerator during - most times it will catch - not always. Then, other times, it starts fine. . . what does this sounds like guys?
12752 is offline
post #12 of 16 (permalink) Old 07-31-2018, 02:06 PM
Hey guys, I am new to to the Pontiac world! So, here's my first issue I have run into with my new-ish baby! &#x1f615;
About 95% of the time, when I go to start up my car, it'll turn over, start to run, but dies almost immediately after unless I give it plenty of gas! I have no check engine light on, nor is little wrench light on, (which seems odd because it seems these cars are very sensitive & alert you to the slightest issue!) I've racked my brain trying to figure out what it could be, Googled my heart out and have come up with no solution or answer to my problem! It's so embarrassing when A.) It dies, or B.) I sound like I'm trying to intimidate/race the old lady loading her groceries into her car next to me in a parking lot. Any help/suggestions and or possible resolution to this issue would be simply amazing and very much appreciated!!! <img src="https://www.g6ownersclub.com/forum/images/smilies/original/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> <img src="https://www.g6ownersclub.com/forum/images/smilies/original/redface.gif" border="0" alt="" title="Embarrassment" class="inlineimg" /> Thanks in advance! <img src="https://www.g6ownersclub.com/forum/images/smilies/original/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
Yeah, mine is just when I try to start it, it never bogs out at a stop. We cleaned my injectors, and throttle body. We did some research on other sites and think it may actually be the fuel pressure regulator. I havery read that that this is I really common problem with the 05 G6! Ordered the part, will update if it fixes the issue! <img src="https://www.g6ownersclub.com/forum/images/smilies/original/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
HI I was wondering if you ever resolved this issue? We have a 2006 G6 and it’s exactly as you’ve described when starting. I hope you found the solution!
Melynda Ezell is offline
post #13 of 16 (permalink) Old 08-01-2018, 12:45 PM
Mine has done it since I got it. Although I do have a check engine light on
Glucas84 is offline
post #14 of 16 (permalink) Old 04-17-2019, 08:40 PM
Check out the manual the car comes with look in the index finger starting your car it say this happen leave your key in the start position for ten second then try it again with the gas pedal did it like that for so long till I read that lil book in my dash,,,&#x1f604;
Twistedg6$ is offline
post #15 of 16 (permalink) Old 04-17-2019, 08:42 PM
oh it pressing gas sorry
Push button start gs1990-G6GT Appearance Modifications and Lighting 7 08-20-2012 09:53 AM
2005 g6 dies and then nothing jlrathel Problems and Solutions 1 02-25-2012 12:25 AM
So my brake pedal squeaked when I push it down and... THECATMAC Problems and Solutions 4 01-03-2011 03:37 PM
Gas Pedal Mod dude12nothin Appearance Modifications and Lighting 5 08-06-2010 11:42 AM
Vibration in gas pedal when taking off Wingyj14 Problems and Solutions 4 06-23-2009 01:45 PM
