Rear end knocking '08 G6 Sedan - Pontiac G6 Forum
post #1 of 8 (permalink) Old 10-14-2014, 05:58 PM Thread Starter
Hi All. I've read through a number of threads talking about this issue and may be getting closer to a solution but not yet!
When I drive over even the smallest bumps in the road theres a knocking in the back. Sounds like its coming from the trunk area.
Here's what I've done so far:
Replaced the shocks
Checked all suspension connections with car fully lifted off the ground
Sway bar and links/bushings
replaced the rear bumper after a rear-ending. they also had to reshape some of the trunk area, but still, after all that, the knocking remains.
Checked wheels
Checked the spare tire/jack.
Moved the trunk felt around.
Pulled down the rear seats (to find out if it was the latch and to hear the knocking better).
Its definitely under the trunk. I've checked just about everything, shook things, etc etc. It only happens while im driving. shaking the car up and down and side to side does not reproduce the sound.
Someone mentioned a place where the trunk and bumper and muffler meet, but not sure what they mean as the muffler hangs down off some rubber deelies that also do not reproduce the sound.
Does anyone have any ideas?
joel is offline
post #2 of 8 (permalink) Old 10-14-2014, 06:51 PM Thread Starter
continuing
I've pulled everything out of the trunk and any pieces that could be rattling.
Its definitely not in the trunk area. I've moved the plastics and stuffed paper towel against any plastics that could be knocking against each other, thats not it either. I replaced the shocks but not the shock mounts. Perhaps that is it? Anyone think that could be the cause?
joel is offline
post #3 of 8 (permalink) Old 10-17-2014, 12:18 PM
Wouldn't hurt to try the mounts. I would think they would be a minimal cost.
Have someone drive your car, while you are in the "back" (with your seatbelt on of course.....) Perhaps you can figure it out that way.
sahls05pg6 is offline
post #4 of 8 (permalink) Old 11-09-2014, 03:33 PM Thread Starter
Angry Think i got it
Alright so the problem seemed to be getting worse and when I was putting my snow tires on I decided to check it out once more.
Forcing the rear sway bar up I was able to reproduce the knock.
So i picked up some new sway bar bushings and went to install them, as I believe this is the source of the issue.
Guess what... the bolt that holds them on broke off. I actually had to grab the acetylene torch to heat up one to get it off. When I got to the other one trying to loosen the bolt (on the opposite side from the one I torched) it actually snapped off. Now I have to take the whole rear end off basically to rebore and tap the hole to put a new bolt in. WTF... a 1 hour job just turned into easily a 5 hour job. GREAT
joel is offline
post #5 of 8 (permalink) Old 11-11-2014, 07:25 AM
Damn that sucks, I'm doing mine next week. looks like i'll have to be careful.
post #6 of 8 (permalink) Old 06-06-2018, 01:45 PM
I have finally solved the rear end noise issue, well, maybe it was just my issue. My mechanic, dealership and a suspension shop had no luck in pinpointing my rear end clunking noise that sounded like my car was falling apart until today. I was shaking every part of the rear end to find out that all this time, that both my tail light assembly were loose. Each taillight has two nuts accessible from inside the trunk and now there is absolutely no noise in the rear end. Hope this helps someone else and I've had the vehicle since it was brand new and have never replaced a build in the back, so the nuts must work there way loose over time.
Speeddemon84 is offline
post #7 of 8 (permalink) Old 06-06-2018, 01:47 PM
Originally Posted by Speeddemon84 View Post
I have finally solved the rear end noise issue, well, maybe it was just my issue. My mechanic, dealership and a suspension shop had no luck in pinpointing my rear end clunking noise that sounded like my car was falling apart until today. I was shaking every part of the rear end to find out that all this time, that both my tail light assembly were loose. Each taillight has two nuts accessible from inside the trunk and now there is absolutely no noise in the rear end. Hope this helps someone else and I've had the vehicle since it was brand new and have never replaced a bulb in the back, so the nuts must work there way loose over time.
post #8 of 8 (permalink) Old 08-15-2019, 07:46 PM
Thanks for coming back and posting your resolution!! I'm thinking I'm dealing with the same issue and the knocking noise is driving me to drink. I always have, but still....
spicerg6 is offline
Rear End Noise THusted General Maintenance 13 06-06-2018 01:44 PM
Rear end Issue AnconaGT Handle It! - Suspension, Wheel and Tire Modifications 3 06-26-2013 07:19 AM
Knocking issue (front end) gearhead Problems and Solutions 6 05-09-2012 07:38 AM
Faint knocking or rattle from passenger front end jaimeace Problems and Solutions 1 02-15-2011 08:36 AM
2005 G6 V6 Rear knocking sound Diavolo Problems and Solutions 2 02-13-2011 01:40 PM
