07 G6 "Reduced Engine Power" - Pontiac G6 Forum
post #1 of 31 (permalink) Old 02-09-2009, 07:14 PM Thread Starter
Salpacn9's Avatar
I have a 2007 Pontiac G6 GT 3.5 liter V6. One day I drove it and the check Engine light came on and a message came up on the display "Reduced Engine Power". The car started to run very badly. I parked it, looked under the hood saw no signs of anything wrong, disconnected the battery to reset the computer and the car ran fine!!! It happen again two days later!!! what would cause the car to do this????
Salpacn9 is offline
post #2 of 31 (permalink) Old 02-10-2009, 05:37 AM
Lifetime Member
geewhiz's Avatar
Donno. Let us know if you find out!
Anyone else?
Pooner, you seem to know it all, any sugestions?
Mike
MODS;
geewhiz is offline
post #3 of 31 (permalink) Old 02-10-2009, 09:25 AM
There is an issue with your throttle actuator control.
This is what I got from gm service information
Reduced Engine Power Mode
When the ECM detects a condition with the TAC system, the ECM may enter a reduced engine power mode. Reduced engine power may cause one or more of the following conditions:
• Acceleration limiting--The ECM will continue to use the accelerator pedal for throttle control, however, the vehicle acceleration is limited.
• Limited throttle mode--The ECM will continue to use the accelerator pedal for throttle control, however, the maximum throttle opening is limited.
• Throttle default mode--The ECM will turn OFF the throttle actuator motor and the throttle will return to the spring loaded default position.
• Forced idle mode--The ECM will perform the following actions:
- Limit engine speed to idle by positioning the throttle position, or by controlling the fuel and spark if the throttle is turned OFF
- Ignore the accelerator pedal input
• Engine shutdown mode--The ECM will disable fuel and de-energize the throttle actuator.
The tac system is the throttle actuator control
post #4 of 31 (permalink) Old 02-10-2009, 10:57 AM Thread Starter
Salpacn9's Avatar
Thumbs up throttle actuator control
Thanks for the info!!! I'll look into the throttle actuator control and see if there is a issue,and I'll let you Know the out come, ether way!!! I was thinking on the lines of O2 sensor or something to do with the Emissions/Cat etc!!!!
Salpacn9 is offline
post #5 of 31 (permalink) Old 02-12-2009, 09:36 AM Thread Starter
Salpacn9's Avatar
Up-Date
Ok had to wait for the check Engine to come on again so I could check the codes. I got two codes (P1515 / P2101)!! P1516 refers to the TAC and says The ECM has detected an out of range condition between the predicted and actual throttle position. P2101 refers to the Throttle Position sensor, And says that the TP senor does not agree with the APP. It Further stated that the ECM has detected the TPS angle does not agree with the APP commanded angle. What the Hell!!! LMAO
Salpacn9 is offline
post #6 of 31 (permalink) Old 02-12-2009, 12:42 PM
Wink
Im not a Pontiac Tech....I had to pull a favor at another G6 site to get that info from one.
I recommend a trip to your local stealerhip service department.
post #7 of 31 (permalink) Old 02-13-2009, 12:45 AM Thread Starter
Salpacn9's Avatar
Thumbs up Good Call
Salpacn9 is offline
post #8 of 31 (permalink) Old 02-13-2009, 05:23 AM
Lifetime Member
geewhiz's Avatar
Originally Posted by Salpacn9 View Post
Good call Lampoon! See, you are a know-it-all!
Mike
MODS;
geewhiz is offline
post #9 of 31 (permalink) Old 02-14-2009, 09:57 PM Thread Starter
Salpacn9's Avatar
Thumbs up Up Date!!!!
Ok heres the deal, I took the Throttle body off, cleaned it (looks like new!!) real good and then I checked the Module on the side of it for moisture and the connection!!! Put every thing back together,and so far every thing is good ( no check engine light- no Reduced Engine Power mode,and the car is running fine!!!
Lampoon you are the man thanks again for that ON THE MONEY CALL!!!!
You And this Forum Are Great!!! And I hope that this thread can help others solve some issues that they might have with their G6 Thanks A Million plus
A Million
Salpacn9 is offline
post #10 of 31 (permalink) Old 02-15-2009, 02:06 AM
sweeeet!!
post #11 of 31 (permalink) Old 02-15-2009, 08:47 AM
Lifetime Member
geewhiz's Avatar
Great work!
Mike
MODS;
geewhiz is offline
post #12 of 31 (permalink) Old 06-23-2009, 08:23 PM
Kinda the same question.
I am kinda having the same problem except that reduced engine power message didnt start till I drove through some standing water on the road. My car died and I tried to start it. (trying to get my kids home in tornado weather) The next morning there was water in my air intake and my air filter was soaking wet. When I took my car to the shop they said that there was water in my oil. Now my reduce engine power message and check engine light come on every time it rains. Any suggestions what my problem might be? Did I damage my engine or flood it?
browneyedangel85 is offline
post #13 of 31 (permalink) Old 06-24-2009, 11:14 PM
water....is....bad....in....an....engine. from my short experience with cars, i know for a fact that water is very bad for any motor. call me out if you will, but i would have the engine rebuilt depending on how much water and damage it caused OR have someone (or you) flush the hell out of the motor and somehow let the water evoporate. if it were me, i would park it til the motor was looked at to prevent any damage.
question: how did water get into your motor? you said you drove through standing water? how deep? if you submerged your car enough for the intake to suck water in...your engine is screwed and needs rebuilt big time. the reasons for a rebuild is one: repair internal damaged parts two: get the water out as it wont just evaporate three: rust may form or be forming four: electrical components shorted out five: you can replace the parts for performance parts like bored cyclinders, oversized pistons/forged pistons/cams.
not only will your motor need a rebuild some of your electrical parts may have shorted out causing your ECU to do funky things. hope i helped a bit. its what i would do if i went scuba diving with my g6.
jamestg6gt07 is offline
post #14 of 31 (permalink) Old 06-25-2009, 04:44 AM
Premium Member
KB G6's Avatar
For some reason I don't think someone that uses their G6 to get their kids away from a tornado needs all that.
Keith
2005 G6 GT
K&N drop-in filter, Pennzoil Platinum 5W-30, 50% tint all around, other than that completely stock
SOLD 11/20/2010
KB G6 is offline
post #15 of 31 (permalink) Old 06-25-2009, 04:56 PM
its just an option to consider since the motor will be torn apart anyway.
depending on the damage to the parts in the motor, i would have the cyclinders bored out, replace all the parts damaged or not. if the motor is fairly new and want to save a little money just have the motor tore apart and cleaned and put back together.
you never know, the extra mm could be all it would take to escape a tornado
New G6 Owner here, First thread! Stabbin_G6 New Member Introductions 10 04-12-2011 11:59 AM
2009 G6 details chiefpontiac G6 Buyer's Guide/General Information 3 06-06-2009 07:17 PM
2007 G6, 2.4L Engine Noise Dusty35 Problems and Solutions 13 02-24-2009 07:55 AM
'07 G6 GT Convertible Ordered....FINALLY!!! WolvesDen Members' Rides 2 06-10-2006 09:55 PM
