P0011 - Pontiac G6 Forum
post #1 of 8 (permalink) Old 08-14-2018, 02:02 PM Thread Starter
My2ndCar-My1stG6's Avatar
P0011
CEL just came on this morning. Got the codes read at AutoZone. Something to do with camshaft. The man told me it's probably a sensor.
Will this be problematical the linger it goes without fixing? What can I expect to happen with this code? Is it an easy fix?
My2ndCar-My1stG6 is offline
post #2 of 8 (permalink) Old 08-14-2018, 10:58 PM
ASE expert
jayram1408's Avatar
Here is your diagnostic procedure
ID:	13465   Click image for larger version
ID:	13467   Click image for larger version
ID:	13469   Click image for larger version
ID:	13471   Click image for larger version
jayram1408 is offline
post #3 of 8 (permalink) Old 08-14-2018, 11:00 PM
ASE expert
jayram1408's Avatar
the rest
ID:	13475   Click image for larger version
post #4 of 8 (permalink) Old 08-15-2018, 07:21 AM Thread Starter
I'm going to try the oil change first due to the fact that it's a thousand miles over due
post #5 of 8 (permalink) Old 08-16-2018, 12:36 AM
ASE expert
jayram1408's Avatar
A trick I learned a long time ago is put a half a quart of tranny fluid in your engine a half hour before you change it. Drive it around for those 30 minutes. Then change your oil. All the detergents in Automatic Transmission Fluid will clean your crankcase, oil passages, ect... When your new oil is in you will have a hard time seeing it on the dipstick as it will be that clean along with the rest of the inside of the crankcase.
post #6 of 8 (permalink) Old 08-16-2018, 09:17 AM Thread Starter
Wouldn't that add a risk of over filling your tranny fluid? The idea sounds reasonable, just worried that I'd be adding too much fluid. Although half a quart isn't very much haha
post #7 of 8 (permalink) Old 08-17-2018, 12:23 PM
ASE expert
jayram1408's Avatar
In your ENGINE crankcase DUH
post #8 of 8 (permalink) Old 08-20-2018, 10:52 AM Thread Starter
So I went to a Take 5 to get my oil done (2,000 miles behind). Service man walks up and tells me that due to the engine ticking that he would have to turn me away due to liability. I agreed and understood but asked if he could check my oil level anyways. I explained to him that I experienced the ticking problem before and it turned out to be because of low oil. He agreed and told me if it was low that he could take me in and add a couple quarts if need be. Dude checks my dipstick, tells me I'm good on oil and recommended me to a "full service" shop.
Later that day I got ahold of a friend who agreed to help me change my oil. Turns out the car was barely holding all of 2 quarts. Changed it out and the ticking went away. Well my CEL is still on, should I take it to a shop and have them erase the code to see if it comes back? He also suggested I clean my valve cover due to the oil buildup.
persistent P0011 & P0014 bmucitelli Problems and Solutions 0 06-07-2016 09:00 AM
P0011 code and engine wants to gallop at an idle Pizzaman6551 Problems and Solutions 3 09-17-2015 12:49 PM
error code P0011, low oil, slight thumping sound on acceleration kq702 Problems and Solutions 9 08-07-2012 03:04 PM
Check Engine Light P0010 & P0011 AllanR Problems and Solutions 3 04-14-2012 12:55 PM
p0011/p0010 and Hard Shifting ?????? Resin8or Problems and Solutions 15 10-04-2011 02:05 PM
