2007 GT 3.9L Convertable Leak - Pontiac G6 Forum
 3Likes
  • 3 Post By Super 8
post #1 of 4 (permalink) Old 11-01-2018, 10:22 AM Thread Starter
I have searched for this problem and cannot find another post. So... My convertible top leaks on both sides right where the 2 seals meet in the front corners. It only happens when it rains very hard, not even in a car wash. When it rains hard, it leaks really bad though. Has anyone else had this issue? I attached an image where it leaks from both sides. It is much worse on the driver side though. Please help!
killroy134 is offline
post #2 of 4 (permalink) Old 11-02-2018, 05:25 AM
On the outside of each visor (rough location) there is a drain hole in the door seal that will need to be cleaned out. It exits the water above the top hinge area of each door.
buzz1009, zenish and killroy134 like this.
Super 8 is offline
post #3 of 4 (permalink) Old 11-02-2018, 04:16 PM
2007 G6 GT conv
Thank You so much. I have a leak too but could not locate it. Will clear that drain hole.
buzz1009 is offline
post #4 of 4 (permalink) Old 11-07-2018, 12:08 PM Thread Starter
Thank you Super 8. It got warm enough over the weekend to try and find this (assuming that the top must be up to clear the drain holes). I did not see anything that looks like a drain. I will look again today though after re-reading your message.
2007 G6gt Convertable nightmanx1 General Maintenance 3 01-07-2018 08:53 AM
2007 g6 gt 3.9l Cars are dope Members' Rides 5 11-16-2017 12:31 PM
2007 Hard top Convertable problem tmtmtl Problems and Solutions 1 09-30-2014 08:14 AM
2008 G6 gt convertable shttea2000 New Member Introductions 5 03-28-2014 12:04 AM
2007 GT 3.9L to 3.6L engine swap TGillman255 Powertrain Performance Modifications 13 04-01-2010 02:25 PM
