2009.5 Power Seat Lift Broken, not electrical - Pontiac G6 Forum
post #1 of 2 (permalink) Old 02-21-2019, 11:17 PM Thread Starter
I picked up a 2009.5 G6 and the power lift function is broken. It works but there is a tear in the seat close to the lumber lever and when I activate the switch to lift the seat, a metal bracket comes up through the hole in the seat. Any ideas how to fix this? I will have to dig into it and take it out of the car but figured I would see if this is common.
RapMastaC1 is offline
post #2 of 2 (permalink) Old 02-22-2019, 10:52 PM
davez26's Avatar
That sounds like the seat frame is broken somewhere.
Look underneath as you use the switches to go up or down, you should have parallel movement.
You might me able to have it welded, but you have to strip it first. If you have skills, it isn't that bad. If not, it might be best to swap with a known good seat.
Sent from my XT1635-01 using Tapatalk
davez26 is online now
Suspension lift... hurleyman77 Handle It! - Suspension, Wheel and Tire Modifications 0 11-19-2015 05:55 PM
Broken driver seat silentsnow31802 Problems and Solutions 2 12-10-2011 05:09 PM
g6 06 gtp power driver seat broken , 06gtpg6 Problems and Solutions 4 07-31-2011 07:37 PM
Right side of drivers seat seems broken Blackhawk131 Problems and Solutions 3 08-30-2010 03:04 PM
