2007 G6 3.5l wont crank - Pontiac G6 Forum
 1Likes
  • 1 Post By plano_doug
post #1 of 4 (permalink) Old 04-07-2019, 01:15 PM Thread Starter
So recently bought a 2007 3.5l g6 and it was starting fine when I first bought it but it needed a neutral safety switch so I already planned to replace it. So one day it just wouldn't start checked all the fuses and the battery and all of that was fine.The security light wasnt on. But it wouldn't crank at all tried jumping it and nothing. So I ended up replacing the neutral safety switch hoping it would work since I needed a new one but nope. Ended up pulling starter off so I decided to test it and it ended up being bad because it wouldn't work sometimes. I replaced the starter with a working one and it still doesn't start. Checked all the wiring to the starter and it seemed fine.Then just the other day it started up.I just dont know what it could be and was wondering if anyone could help or give ideas on what it could be.
Csp13 is offline
post #2 of 4 (permalink) Old 04-08-2019, 06:14 AM
Old far...er...tinkerer..
Ignition switch or starter relay. When it won't start, you need to put a voltmeter on the small wire on the starter solenoid and see if you have +12V when the key is turned. If you see +12V, then the starter should turn.
If no +12V, then pull the starter relay from the underhood fuse block and probe it to see if you see +12V across the coil (input) terminals when the key is turned to crank. If no +12V there, then the issue is upstream in either the computer or the ignition switch.
If you see +12V on the coil, then the relay is bad. Try swapping another relay from the same fuse box and see if cranks then. If so, get a new relay.
After that, you will need to start probing the ignition wiring and computer wiring. But try the relay and starter solenoid first.
Doug
hubertk likes this.
plano_doug is offline
post #3 of 4 (permalink) Old 04-08-2019, 06:45 PM Thread Starter
Doug
okay so I checked the wire on the starter and nothing. Switch the relays around and nothing. Tried to get a reading from fuse box where the relay would go in and its getting the constant power but if I put in the tester to where I'd assume would be the power to the starter when the key is cranked I get nothing I believe it was the hole where on the relay it says 30 and from what I read that should be the one to the starter. So how would I go upon testing the ignition switch exactly?
Csp13 is offline
post #4 of 4 (permalink) Old 04-08-2019, 07:49 PM
I've attached a couple of drawings pertaining to ignition/cranking.
You've probed pin A at the starter, purple wire, and had no voltage. So work back from there. Check continuity of the purple wire back to C1-D12 in the underhood fuse block (relay 31). Does relay 31 click during crank? Does the purple/white wire at C1-E12 go high during crank? Does C2-E11 ohm to ground?
And so on....
HTH.
Doug
ID:	13819   Click image for larger version
Wont start on first try 2007 g6 wall1234 Problems and Solutions 1 08-16-2018 07:31 AM
07 g6 3.5L will not crank. Starter issue? Mikeduno1 Problems and Solutions 0 02-09-2018 03:59 PM
07 G6 base 3.5L AC compressor wont engage YukonCharley Problems and Solutions 0 05-31-2017 03:16 PM
2008 g6 wont crank Justinraymon Problems and Solutions 0 01-11-2016 12:59 PM
2008 G6 GT 3.5L Won't crank, nor start Furnatic Problems and Solutions 20 01-11-2013 02:10 PM
