2008 pontiac G6 start problem - Pontiac G6 Forum
 1Likes
  • 1 Post By Convertme
post #1 of 4 (permalink) Old 07-31-2019, 08:00 AM Thread Starter
is it necessary to have a functioning key fob to start the car. I have checked all the fuses, mini relays, etc. Still can't start the car. I need help!
hubertk is offline
post #2 of 4 (permalink) Old 07-31-2019, 09:22 AM
Pretty sure you that you don't need one. but the key you have needs to be the proper one. And it likely has a chip in it that needs to match the car.
zenish likes this.
Convertme is online now
post #3 of 4 (permalink) Old 08-01-2019, 09:55 AM
davez26's Avatar
Fob doesn't matter.
Correct transponder key, and car programmed to recognize it are necessary.
Key may turn in cylinder, but without programming, worthless.
Without a recognized key, it's a tow to a shop to get programming done, unless you can find a mobile to do it.
Programming is usually a charge per session, so I recommend to get 2 or more done at a time. Keys not on hand at time of programming become unrecognized and are erased from vehicle.
Sent from my XT1635-01 using Tapatalk
davez26 is offline
post #4 of 4 (permalink) Old 08-07-2019, 05:52 PM
I bought a programmer on eBay for $100 and it worked fine for me. Might not be worth the money if that's the only key you'll ever do.
hamptonbeach is offline
