2007 g6 power steering hose - Pontiac G6 Forum
post #1 of 3 (permalink) Old 04-21-2018, 01:17 PM Thread Starter
Is this the correct power steering hose for the g6 3.5 v6 ? Autozone wants 80$
https://www.carid.com/edelmann/power...xoCYMEQAvD_BwE
Justwayne is offline
post #2 of 3 (permalink) Old 04-21-2018, 05:11 PM Thread Starter
The stock one is bent differently. Is the one pictured the new replacement it's the same straight bend like AutoZones picture not the hook bend like stock. Has anyone replaced one with the newer differently bent pressure line AutoZone sells and does it fit like stock. I saw an eBay ad showing the new 92405 part # pic and a stock pic line with the hook around bend right after the rubber. I'm assuming it's a revised replacement for the stock line?
post #3 of 3 (permalink) Old 04-21-2018, 08:26 PM
I often compare parts with RockAuto.com
They usually have pics posted of the parts with multiple angles.
I can't speak with certainty regarding your situation as my G6 has electronic steering.
sloppy steering after having the power steering recall repaired bradbarker Steering Lockup Issues & Discussion 12 03-25-2019 09:05 AM
2007 V6 leaking power steering UT2007G6 Problems and Solutions 3 09-24-2014 07:43 AM
Steering alignment / geometry electric vs hydraulic power steering boomer Problems and Solutions 8 06-04-2014 07:50 AM
High pressure power steering hose DennisVaz Problems and Solutions 1 03-21-2014 08:01 PM
Power Steering Hose Issue agg28 Problems and Solutions 4 09-07-2013 06:51 PM
