2007 GT 3.9L to 3.6L engine swap - Pontiac G6 Forum
post #1 of 14 (permalink) Old 03-31-2010, 12:52 PM Thread Starter
I wanted everyones input on this. How much do you think we are talking about overall price wise and what all components would need to be installed? The engine alone is roughly 3200, not to mention I'd need a 6 speed tranny, which I'm not sure of the price. What else would I need and would this be a reasonable swap? It would deffinately be a project in the making since I don't have the funds currently. Just wanted some opinions.
TGillman255 is offline
post #2 of 14 (permalink) Old 03-31-2010, 01:02 PM
Varsity Squad
CalsGTP's Avatar
I have just one question.... WHY???? Go from a 3.9 to a 3.6? Just dosen't sound like it would be anywhere worth doing, but you would also need either new computers for engine and trany or reprogramming. You can get pretty good deals from GMPartsdirect.com.
CalsGTP is offline
post #3 of 14 (permalink) Old 03-31-2010, 01:11 PM
GTP 06
maykevin5's Avatar
Send a message via MSN to maykevin5
I'll just let you know now.. Quit thinking about it, won't be done.. not saying can't, but unless you dedicate a nice long time out of your life trying to make it work, it would be faster and cheaper in most cases to buy a GXP.
maykevin5 is offline
post #4 of 14 (permalink) Old 03-31-2010, 03:50 PM
Heavy Modder
why in the WORLD would you want to spend that kinda money for a SMALLER engine!?
06' G6 GT Liquid Silver
Mods So Far
Goodyear Eagle GT Tires, American Racing Black Haze 17" Rims, 8000K Digital HID's, Tinted Tails (and 3rd), Red Painted Calipers,"RE-Painted" Black Exterior Trim, De-Badged, INJEN CAI, Royal Purple 5W-30 Oil, BOSCH Platinum Ir Fusion Plugs, NOLOGY Hotwires (plug wires), Intake Res Delete, Arrow (Reflective Red/Carbon Fiber) overlays, Sirius Satellite Radio! lol
Soon to come
Muffler change or remove
Window Tint
Lowering Springs
Drilled and slotted rotors/Ceramic pads
Black painted Headlights
GAME OVER IX is offline
post #5 of 14 (permalink) Old 03-31-2010, 07:32 PM
GTP 06
maykevin5's Avatar
True smaller.. but more horsepower by 40 i think.. High compression tuned 3.6 still not worth it i think
post #6 of 14 (permalink) Old 03-31-2010, 07:46 PM
ralthoff's Avatar
Mine has the 3.6, and I agree, it would be better just to trade to a GXP. Not only would you have the 3.6 then, but the 6 speed auto stick, awesome body, faux duel exhaust, and what sold me on the car... heated leather seats :-P
ralthoff is offline
post #7 of 14 (permalink) Old 03-31-2010, 08:58 PM
Varsity Squad
CalsGTP's Avatar
My 06 GTP with the 3.9 had 240hp @ crank when stock and the GXP with the 3.6 has 251hp stock a difference of 11hp stock. With exhaust, intake, and jet stage 2 module my GTP dynoed @ almost 265hp @ crank. I dont know why the GXP did not have the option for a REAL 6 speed manual trans like my GTP.
Straight from Motor Trend:
2006 Pontiac G6 GTP Coupe Performance & Efficiency Standard Features
- 3,880 cc 3.9 liters V 6 front engine with 99 mm bore, 84 mm stroke, 9.8 compression ratio, overhead valve, variable valve timing/camshaft and two valves per cylinder LZ9
- Unleaded fuel 87
- Fuel economy EPA highway (mpg): 29 and EPA city (mpg): 21
- Multi-point injection fuel system
- 16 gallon main unleaded fuel tank
- Power: 179 kW , 240 HP SAE @ 6,000 rpm; 240 ft lb , 325 Nm @ 2,800 rpm
2009 Pontiac G6 GXP Sedan Performance & Efficiency Standard Features
- 3,564 cc 3.6 liters V 6 front engine with 94.0 mm bore, 85.6 mm stroke, 10.2 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder LY7
- Unleaded fuel 87
- 16.4 gallon main unleaded fuel tank 13.7
- Power: 188 kW , 252 HP SAE @ 6,300 rpm; 251 ft lb , 340 Nm @ 3,200 rpm
My GTP also has heated leather seats too ralthoff.
CalsGTP is offline
post #8 of 14 (permalink) Old 03-31-2010, 09:02 PM
ralthoff's Avatar
Heated seats are where its at :-P
ralthoff is offline
post #9 of 14 (permalink) Old 03-31-2010, 09:09 PM
Varsity Squad
CalsGTP's Avatar
FOR SURE! Makes a huge difference when dealing with those cold winter days, too bad they dont cool off for those hot summer days!
CalsGTP is offline
post #10 of 14 (permalink) Old 03-31-2010, 11:16 PM
Fuzz12285's Avatar
spend like 3 grand and get more hp than the 3.6....?
higher compression pistons, lightened + cryo'd rods, and then tune for the higher compression...
Fuzz12285 is offline
post #11 of 14 (permalink) Old 04-01-2010, 01:34 AM
Fried like a Cheese Stick
Droptop Diamond's Avatar
What were the actual dyno #'s?
09 White Diamond Tricoat 'vert here!
Now with CRABs, STBs, & The Heart Ruling The Mind!
Odd random pics on my facebook page http://www.facebook.com/profile.php?id=100001119651822
Droptop Diamond is offline
post #12 of 14 (permalink) Old 04-01-2010, 02:25 AM
Holy Balls Cal, I didn't know you dynoed at 265. Did you post that at one time and I missed it or what?
Was that the corrected gain or actual?
jetmech_5 is offline
post #13 of 14 (permalink) Old 04-01-2010, 09:55 AM
Varsity Squad
CalsGTP's Avatar
265 @ the crank was the adjusted rating for the crapy weather, altitude, and all that stuff. The day I ran was like 80% humidity and in the high 80's, not the ideal day for running on the dyno, but they had some program that adjusted for all that and the loss from the crank to the wheels.
CalsGTP is offline
post #14 of 14 (permalink) Old 04-01-2010, 02:25 PM
Daniel's Avatar
What is a Jet stage 2 module?
Ive only heard of two ECM flash companys but never heard of that.
Daniel is offline
Check Engine/Scv Vehicle Soon/Reduced Engine Pwr Indicators all on? insiminator Problems and Solutions 7 09-19-2010 08:21 AM
monsoon swap?? 08G63.5 Car Audio, Video and Security 0 04-27-2009 10:50 PM
2007 G6, 2.4L Engine Noise Dusty35 Problems and Solutions 13 02-24-2009 07:55 AM
tapshift swap sneaux96 Powertrain Performance Modifications 2 06-24-2008 11:18 AM
6 Disc Swap coopcj7 Car Audio, Video and Security 2 01-16-2008 09:52 PM
