2006 HHR 16" wheels fit on 2009 G6 Base Sedan?? - Pontiac G6 Forum
post #1 of 7 (permalink) Old 01-12-2012, 06:39 AM Thread Starter
I've been searching and haven't found an answer yet; so will 2006 HHR 16" wheels fit on a 2009 G6 Base Sedan? The G6 came with 17" steel wheels with covers. I'm thinking that they would fit since the HHR wheels fit cobalt SS's and knowing that cobalt's fit G6's it should fit ok, right?
Thanks for your help!
Danza is offline
post #2 of 7 (permalink) Old 01-12-2012, 07:33 AM Thread Starter
here's a little more info I found, the HHR wheels are 16 x 6.5 and the stock G6 wheels are 17 x 7". still cant find any offset info though....
Danza is offline
post #3 of 7 (permalink) Old 01-12-2012, 07:36 PM Thread Starter
Well they fit. I ended up getting a set of the 06-07 factory 16" alloy wheels with winter tires off of Craigslist pretty cheap. The offset is a little less so there tucked in a little more. But not bad at all to me.
Danza is offline
post #4 of 7 (permalink) Old 01-13-2012, 01:24 PM
reverttheclown's Avatar
how did you fix the bolt pattern problem
2006 Pontiac G6 V6 3500L
Crimson Red
reverttheclown is offline
post #5 of 7 (permalink) Old 01-13-2012, 10:23 PM Thread Starter
5x110
They're the same bolt pattern
Danza is offline
post #6 of 7 (permalink) Old 01-14-2012, 08:26 AM
i see....well good find!
Crimson Red
post #7 of 7 (permalink) Old 02-02-2012, 07:54 PM
Hollywood__'s Avatar
Almost any rim with a 5 x 110 bolt pattern that has a hub bore of 65.1 and an offset between 35 and 45 will work on a G6. Of course it needs to be at least the same size (16" / 18" etc) or larger than what you currently have to clear the calipers.
The HHR rims should work fine... There are a lot of GM cars that have interhchangeable rims. Soltice / Sky / Cobalt / Aura / LaCrosse, and basically anything on the Epsilon platform. I found a list of all GM cars that shows bolt pattern and hub bores / offsets. I will post a link as soon as I can find it again.
Hollywood__ is offline
2006 base sedan Darin.Overturf Items for Sale 0 10-24-2011 08:41 AM
2006 GT 17" Premium Wheels kmr181 Items Wanted 2 07-11-2009 01:27 AM
