06 gtp front end grinding noise - Pontiac G6 Forum
post #1 of 3 (permalink) Old 05-10-2016, 04:35 PM Thread Starter
I have a grinding noise coming from my passenger side thought it was my strut it only did it when I turn one way. So I replaced my struts and links and still have the noise seems like it's coming from the inner tie rod towords the middle. Any one able to help me out the noise it quite loud then turning.
Spriggsgtp is offline
post #2 of 3 (permalink) Old 05-12-2016, 04:35 PM
The front noise for me was the wheel bearing hub assembly. More of a groan or whine as I recall I ended up changing both in the end as once I fixed one, I could clearly hear the other. My car was about 110k miles when I started to notice. Mine also varied in sound with slight changes in direction (guessing as I added more load to the left or right wheel)
boomer is offline
post #3 of 3 (permalink) Old 05-13-2016, 08:04 AM
grinding noise while turning is usually your axle.
front end noise joancasti Problems and Solutions 1 04-03-2015 02:37 PM
Clunking noise front end eggbert55 Problems and Solutions 3 10-14-2013 09:52 AM
Front end noise (maybe strut) nwohio Problems and Solutions 18 05-06-2012 07:45 PM
front end noise bob imburgia Problems and Solutions 0 12-24-2010 09:11 PM
front end NOISE ! Help appreciated..... Crossroads Problems and Solutions 7 05-13-2010 03:26 PM
