fog lites installation - Pontiac G6 Forum
post #1 of 3 (permalink) Old 07-14-2012, 02:35 PM Thread Starter
need help in installing aftermarket fog lites on a 08 without factory fogs,is anything pre wired ,can the fogs be set up to come on with the regulat lights?
deverd is offline
post #2 of 3 (permalink) Old 07-14-2012, 03:47 PM
Nothing is pre-installed. You can buy OEM fog lights for the G6. You just need to cut the little grills and the fog lights will snap right in. Then it's a matter of wiring it however you want. Either on a switch or with the parking lights or headlights.
Here are the stock fogs:
Ebay
I just did a quick eBay search, There are plenty more listings.
I installed aftermarket fogs on my G6. I got them from walmart:
They fit right into the stock holes, but mounting them was a little tough. I had to Set Screw them in, I then wired them to my parking lights so they'll always be on with the lights, I also added a switch.
I also added yellow lamin-x to make the lights yellow. Only problem is they come with really high powered bulbs and get really hot, So if you chose those I would recommend replacing the bulbs with lower wattage.
post #3 of 3 (permalink) Old 07-14-2012, 06:20 PM
I went crazy elaborate on mine. I bought a factory headlamp harness with fog option a factory switch for the dash and the pigtail for it. I then installed the harness and fogs then took it to a mobile electronics shop to have the switch wired in.
[SIGPIC][/SIGPIC]
HID Installation tmfrosch9 Appearance Modifications and Lighting 5 07-17-2011 06:03 PM
HID Installation help!!! (desperate!) Raptor Appearance Modifications and Lighting 91 02-21-2011 09:36 AM
halo installation rani Appearance Modifications and Lighting 9 09-14-2009 02:41 PM
HID Installation asong10 Appearance Modifications and Lighting 3 02-07-2009 11:57 AM
08 GXP HID Installation coolmanvette75 Appearance Modifications and Lighting 4 03-26-2008 02:32 AM
