2007 G6 Parking Light Wiring?? - Pontiac G6 Forum
post #1 of 7 (permalink) Old 12-20-2013, 10:24 AM Thread Starter
So I'm modding my headlights; putting in some LEDs and Oracle CCFL Halos.
I want to wire them so they're on when the parking lights are on.
Looking at the parking light wiring on the headlight, I'm getting confused
The small bulb behind the triangular-shaped orange reflector on the side has 3 wires coming out of it; how do I know which of the 2 to tap into to get constant (not blinking on & off) power to the LEDs and Halos?
I've looked at some wiring diagrams, but they seem to have different color wires than what I have.
If someone could explain which 2 of the 3 wires I should tap into, I'd appreciate it!
Thanks!
crosby1 is offline
post #2 of 7 (permalink) Old 12-20-2013, 12:56 PM
According to the diagram I pulled it's a brown wire that goes all the way from the parking light relay to the lights themselves. Black being the ground.
What colors do you have at the socket?
Do you have a meter or a test light?
That third wire is probably the one that daisy chains the light to the other park/signal bulb. Try looking at the harness before it gets connected to the light itself too. Maybe it's brown there but changes at the plug just before the light.
post #3 of 7 (permalink) Old 12-20-2013, 05:44 PM Thread Starter
crosby1 is offline
post #4 of 7 (permalink) Old 12-20-2013, 05:46 PM Thread Starter
The wires to the parking light are brown and 2 blacks. One of the blacks does indeed go to the parking/signal bulb.
So I assume I'm safe to tap into the brown and use the black one as the ground?
Thanks again
crosby1 is offline
post #5 of 7 (permalink) Old 12-20-2013, 08:08 PM
Yea you should be fine tapping into the brown for power and black for ground.
post #6 of 7 (permalink) Old 12-20-2013, 08:14 PM Thread Starter
Awesome. I'll give it a shot.
Thanks for your help (and moral support)
crosby1 is offline
post #7 of 7 (permalink) Old 12-21-2013, 12:26 AM
No problem! Good luck with everything. I'd try connecting the wires by twisting first to test everything. Then permanently install it.
2007 G6 won't start, but has engine light and car with a padlock light. davadholman Problems and Solutions 11 06-03-2018 12:47 AM
Help 2007 Pontiac G6 GT convertible Check Engine Light On carlos.savinon Problems and Solutions 11 11-09-2012 03:44 PM
2007 G6 Hardtop Convertible - 3rd Brake Light kepley99 General Maintenance 1 10-02-2012 06:56 PM
2007 G6 Headlight and Brake Light Issue pacop312 Problems and Solutions 0 06-20-2011 02:28 AM
wiring info for 2005-2007 g6 sound system..and oh yeah was the info for my 2008 also bubbashrimp Car Audio, Video and Security 8 05-23-2010 09:50 PM
