2.2L '2200' Valve cover gasket oil leak - Pontiac G6 Forum
post #1 of 2 (permalink) Old 11-10-2006, 12:44 PM Thread Starter
sunrunner_pei's Avatar
Lightbulb 2.2L '2200' Valve cover gasket oil leak
For anyone suffering from an oil leak around the valve cover gasket of the 2.2L '2200' engine, here is some help. The gasket is quite inexpensive and not difficult to replace.
Oil stained engine:
To Fix, buy a new gasket:
Remove the air intake resonator box:
Then remove the fuel rail cover:
Then remove the valve cover:
Clean the mating surfaces well:
Then reverse the process:
Do a little cleaning, and you're done!
sunrunner_pei is offline
post #2 of 2 (permalink) Old 02-13-2007, 08:00 PM
#1 instigator
spyhunter's Avatar
Send a message via AIM to spyhunter Send a message via Yahoo to spyhunter
Just in case, what's the Gm torque spec for when refastening the cover?
TREVTEC MOTORSPORTS - LV,NV
[email protected] - 2.3>3.4
shhhh it's going to blow everything out of the water.
"Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you."
spyhunter is offline
  Pontiac G6 Forum > GMOC Archive > GMOC Archived Threads
You may not post new threads
You may not post replies
