2007 G6 Radio Info/Help - Pontiac G6 Forum
post #1 of 2 (permalink) Old 09-02-2013, 02:30 PM Thread Starter
Question 2007 G6 Radio Info/Help
I just bought a 2007 G6. When I purchased it they stated that the radio didnt work. It would only display messages in the info center. Well I messed around with it and nothing would work, volume, radio, fade, balance, etc... So i decided to see if a cd would play and I put it in and it played and that in return made the volume and stuff start working, but the radio still does not work, it just outputs static. I done a seek for stations and it comes up with nothing. I took the radio out and verified that the antenna was hooked up still and it was. Does anyone know what would cause this? Is the tuner out of the radio maybe?
Secondly, I went ahead and swapped that radio out with a non factory radio head unit that I had. Can this be done by just using a wiring harness from walmart for the Pontiac Car? I hooked up the radio and it powers on but nothing comes out on the speakers, not even static. Also as soon as I push source to turn it to the tuner the car lock displays on the dash and all the dash lights go off and the head unit displays amp error. Can anyone tell me the exact steps t hooking up a non factory head unit and with what parts to make it work? Any and all information would be very greatful.
Thank you in advance...
smcs is offline
post #2 of 2 (permalink) Old 10-14-2013, 08:33 AM
do you have monsoon radio
05 G6
ipad mini install
Gametag psn=getonerd 360=geronerd
getonerd is offline
Want a new radio but wanna keep info like oil life, tempeture, wash fluid etc.. festy1986 Car Audio, Video and Security 7 03-16-2014 12:37 PM
Putting a 2009/10 radio into a 2007 G6? Can it be done?q goufcustom Car Audio, Video and Security 6 08-09-2011 06:56 PM
2007 G6 Radio Problem Parttime puller Problems and Solutions 1 03-31-2011 08:33 AM
wiring info for 2005-2007 g6 sound system..and oh yeah was the info for my 2008 also bubbashrimp Car Audio, Video and Security 8 05-23-2010 09:50 PM
