2010 Speedometer Swap HOW-TO - Page 9 - Pontiac G6 Forum
 9Likes
post #121 of 135 (permalink) Old 07-15-2019, 10:20 PM
Yeah you definitely could swap it, the clusters are plug in play so you’ll have no issues there. For the street if wheel if you find the stuff for it all the wires should be there.
Originally Posted by JoeyLovesTrains View Post
Holy crap! I can't believe someone made this so recently! I've been looking for something to help me with this, I want to get a double din head unit with Apple Car-Play/Android-Auto, but I also want to keep the integrated DIC interface. Could I somehow manage to swap the instrument cluster from a 2010, to my 2007, so I can retain all the stock features, while also using an aftermarket radio?
Btw, I don't have any steering wheel control buttons, I'm working on figuring out how to wire ones up if I do get a steering wheel that has one.
Any idea if I would need to change car milage or something? Or are the 2 clusters plug-n-play?
athrall is offline
post #122 of 135 (permalink) Old 07-15-2019, 11:25 PM
Well, after doing some research of mine, I found that most value leader cars don't have all the wires for it, I only have 2 wires that's for the horn, and some for the airbag. Here's the original thread:
https://www.g6ownersclub.com/forum/1...l-upgrade.html
But apart from that, do I need to reset anything on the new cluster once I buy it? (i.e. oil life, milage, trip... Or is that all plug and play? I'm assuming if it is, then the trip, oil life, and everything else, is stored somewhere else on the system, and the DIC is just the interface to access that info.)
I'm not to worried about the buttons just yet (I think I've found a way to do it, just need some time and money), I first want to know if the cluster's are fully plug and play and don't need any reprogramming of any kind. My G6 has no factory keyless entry, cruise control (except for an off brand model), no xm, nothing. So my current DIC doesn't have all the options you would have in most different G6's (i.e. when the car gets locked, if the headlights flash, will the horn beep... stuff like that). So I'm hoping this doesn't change anything, I'm planning on getting an aftermarket radio (preferably a double-din head-unit with all that new tech stuff, but I think I already talked about that).
Really hope I can do this one day! (I'm only 16, this is my first car, and I NEED a job, so this is all just an assurance for future-me who might attempt this project one day).
JoeyLovesTrains is offline
post #123 of 135 (permalink) Old 07-16-2019, 09:25 AM
Yep it’s fully plug and play, everything transfers over. Your mileage will not change.
athrall is offline
post #124 of 135 (permalink) Old 07-16-2019, 11:51 AM
Ok that's perfect!! Thanks so much!! And what about the buttons for the DIC, would I need to relocate them somewhere else? If I replaced the current radio with a double din, I would need somewhere to put the, info, enter, and menu buttons, right?
You've been an amazing help btw!
post #125 of 135 (permalink) Old 07-16-2019, 10:32 PM
Well we may have to get a little creative with that one. That all depends on what connectors you have behind your air bag. I know you have the value wheel without any buttons, but it’s possible that the body harness that goes to the wheel has a good chunk of the wires already there. I know with my g6, it did not come with the audio controls, however the main harness that went to my steering wheel had the wires for it, so when I replaced the wire harness within the steering wheel I was able to add them. With that in mind, I think it would be safe to assume the when they made the car, gm used one general wire harness across all g6/Malibu/aura vehicles, and then just had little additions they added to that harness in order to add the options. Assuming this, I think that not only can we add the dic buttons, but we also might be able to unlock the cruise control(this might need programmed by a dealer) and steering wheel control options. If your looking to tackle this head on, you can send me a private message and I will be willing to help out more. And if for some reason gm did not use the same harness across all models, I can walk you through how to at least get your dic buttons to function.
athrall is offline
post #126 of 135 (permalink) Old 07-16-2019, 10:41 PM
My whole thought around the harness already having the dic wires comes from this. When I installed my 2010 cluster I still had my factory radio installed. And if I used the info/menu buttons on the radio, it would also toggle the settings on the cluster. So that tells me that that system is connected through the data wire, which travels to most everything on the car. That also explains how adding the 2010 radio adds the warning chimes back to the car.
athrall is offline
post #127 of 135 (permalink) Old 07-18-2019, 06:18 PM
Originally Posted by CruisinG6 View Post
No problem! Glad its helping people out!
I'm also really grateful you posted this! I just have one small issue... None of the images are there, as in... NONE of them, they all say:
Photo not found
CLICK FOR PHOTOS
with a cat meowing in the background. Not sure what's happening, but I've tried on different browsers, and nothing's worked. I'm not sure how one would go on fixing this issue. But it would really save me a bunch of hassle if you could somehow get those photos out on this thread. Thanks!
post #128 of 135 (permalink) Old 07-18-2019, 07:41 PM
2007 gt retractable
Photo not found
CLICK FOR PHOTOS
cruising apparently quit paying for the photo storage when he left the forum.they have been gone for a while.
zenish is offline
post #129 of 135 (permalink) Old 07-18-2019, 10:11 PM
I’m in the process of purchasing another g6. With that I’m going to have to do the swap again. Since this thread is starting to get decently active again I will record my entire process, along with any other changes I do to the g6. I will make sure to link the video of the full install here.
athrall is offline
post #130 of 135 (permalink) Old 07-31-2019, 10:31 PM
video walkthrough
For those interested in doing the swap here is the walkthrough for it. I know it doesn't go in the exact order but I did it from memory.
zenish, Convertme and 1of4885 like this.
athrall is offline
post #131 of 135 (permalink) Old 08-01-2019, 05:51 PM
2007 gt retractable
ive had the stuff.maybe i will swap it this weekend.
zenish is offline
post #132 of 135 (permalink) Old 08-01-2019, 10:31 PM
Let me know how it goes I’m glad it helps out
athrall is offline
post #133 of 135 (permalink) Old 08-02-2019, 05:20 AM
Great job on showing everyone how to do this install.
I did the swap on my Daughters 2009 a couple of years ago using the photos and write up.
You Video is much easier to follow and shows how small the pins are that you have to remove and install.
This Video will help a large number of people who want to do this swap but just need a little direction on how to do it.
Once again Great Job :-)
zenish likes this.
Stittville Ed is offline
post #134 of 135 (permalink) Old 08-05-2019, 07:01 PM
Does anyone know the torque spec, or the bolt holding the steering wheel to the steering column? I don't have a clue on what it might be.
thanks!
post #135 of 135 (permalink) Old 08-05-2019, 10:22 PM
That's something to ask for in a the problem and solutions thread
athrall is offline
  Pontiac G6 Forum > Technical Discussion & Modifications > HOW-TO
2010 head unit swap Gobiin Car Audio, Video and Security 10 03-08-2011 03:10 PM
HIN-NOPI 2010 SUPERSHOW SOLDIER FIELD, CHICAGO ILLINOIS September 25, 2010 mcwheels Off-Topics 0 09-15-2010 10:05 AM
HIN-NOPI 2010 SUPERSHOW LOS ANGELES CONVENTION CENTER September 18, 2010 mcwheels The West 0 08-20-2010 08:18 AM
Speedometer increase? skip1681 Appearance Modifications and Lighting 3 04-19-2010 08:44 PM
Speedometer Issue thunkele Problems and Solutions 4 01-14-2005 04:16 PM
