2005 G6 radio - Pontiac G6 Forum
post #1 of 5 (permalink) Old 06-21-2018, 11:27 PM Thread Starter
2005 G6 radio
I am trying to replace my radio with a JVC, I wired up the harness with a interface in it. hooked it up and nothing, would not come on I started looking though the interface manual and see it says the switched power does not come from the factory harness but a relay not sure where it is or if the manual is mistaken the interface is a scosche GM3000sw
crpowell67 is offline
post #2 of 5 (permalink) Old 06-21-2018, 11:54 PM Thread Starter
I do not see a way to delete my thread I put it in wrong area and think I found my problem read that I have to run a wire to switched to either radio fuse or brown ignition wire
post #3 of 5 (permalink) Old 12-13-2018, 04:43 PM
SweStone's Avatar
Did you find out how to do it? I need help aswell
SweStone is offline
post #4 of 5 (permalink) Old 12-14-2018, 02:30 AM Thread Starter
Yes I had to run the power wire to a fuse that came on with the key.
post #5 of 5 (permalink) Old 12-28-2018, 04:53 PM
SweStone's Avatar
How exactly did that happen?
SweStone is offline
  Pontiac G6 Forum > Technical Discussion & Modifications > HOW-TO
