[B]Steering seems rough on 09 G6[/B] - Pontiac G6 Forum
post #1 of 14 (permalink) Old 04-23-2013, 02:18 PM Thread Starter
Question [B]Steering seems rough on 09 G6[/B]
I have a 2009 G6 with the 3.5l V6. It does not have the ECS system. It has the power steering fluid with pump system. My isssue though is that it seems rough. I have driven many cars and this is the first one that feels like this.
I checked my fluids and they seem good. Could it be a power steering pressure hose issue?
negru08 is offline
post #2 of 14 (permalink) Old 04-27-2013, 02:24 PM
Even the electric pump power steering requires fluid. Mine is also having issues keeps wining on small turns and fluid levels check out.
AnconaGT is offline
post #3 of 14 (permalink) Old 04-27-2013, 09:00 PM
Its not an electric pump steering. Its an electric assist motor inside the column that also turns the steering shaft. No fluid being pumped anywhere
post #4 of 14 (permalink) Old 04-29-2013, 08:38 AM Thread Starter
I dont have ECS...I have the model that have a power steering pump and stuff...
negru08 is offline
post #5 of 14 (permalink) Old 04-29-2013, 09:14 AM
What you mean by rough? Does it feel like something is binding or rubbing while you turn the wheel? Or is it just harder to turn than you'd expect?
post #6 of 14 (permalink) Old 04-29-2013, 09:19 AM
It's EPS, Electric Power Steering.
post #7 of 14 (permalink) Old 04-29-2013, 09:58 AM Thread Starter
~slls
Either way I don't have the electric controlled one. That comes on the 2.4 versions.
~CrusinG6
Harder to turn then expected,kinda like its to sharp or tightened. Have always been able to turn the steering wheel with 2 fingers...no way in this car.
negru08 is offline
post #8 of 14 (permalink) Old 04-29-2013, 12:21 PM
mshinall's Avatar
My steering is a little tight. I attributed it to the sporty tuning. I find it easier to steer with a little more stiffer steering. Definitely not like riding in a non power steering car tho.
Sent from AutoGuide.com App
2009 Techno Gray Metallic G6 GXP Sedan (3.6L Auto6 112K miles)
CRAB Intake Opt 3 w/FPU, Lloyds GXP floor mats, HIDs low 6000k 55w/fog 3000k 35w, LED DRLs behind lower grills, V3 Triton LED turn signal/reverse/brake, LED side markers/maps/dome/tag/trunk/high mount stop, 2 coats niteshades on tails, Tint 35% all around, Debadged (except arrows), PAC IPod and BT adapters, PowerStop D/S rotors and ceramic pads, Resonator repl w/24" cherry bomb, Racingline STB, Big 3 Upgrade, Optima Yellowtop D75/25, Blacked out arrows, chrome window trim and black dipped wheels, KYB struts and shocks, CM lowering springs, Cherry Bomb Vortex Crossflow muffler, 2.5" pipe from axle back, two 4" stainless double walled slant tips
...still working...
mshinall is offline
post #9 of 14 (permalink) Old 04-29-2013, 05:58 PM
I have EPS so my info may not be so useful. But I've noticed my steering to be quite a bit stiffer than any other car I've driven, aside from my buddies manualy steered pickup.
Assuming there may be a problem, do you hear any noises coming from the power steering pump while turning the wheel back and forth? Any inconsistency in the power assist while turning it?
Hopefully someone with hydraulic power steering has more info they can share.
post #10 of 14 (permalink) Old 04-29-2013, 08:20 PM
mshinall's Avatar
Mine is hydraulic and I find it to be in line with my expectations. For a test , I tried to steer with two fingers on the way home from work and was not able to. I think its a matter of sporty vs luxury steering. I feel like the stiff steering gives me better feedback which translates to better handling with my "spirited" driving ;-)
...still working...
mshinall is offline
post #11 of 14 (permalink) Old 04-29-2013, 08:30 PM
I would agree. Personally I like the heavier steering, makes me feel like there's something attached to the steering wheel. On my moms Buick I can probably turn the wheel by blowing on it. Everytime i drive her car I over steer like crazy the first few turns haha.
post #12 of 14 (permalink) Old 04-30-2013, 05:52 AM
mshinall's Avatar
Also good to note that the steering gets stiffer the faster you go. At slow speed turns it is much easier to turn such as in parking lots.
...still working...
mshinall is offline
post #13 of 14 (permalink) Old 04-30-2013, 03:05 PM Thread Starter
I guess there just isnt a issue. Going to flush my power steering fluid just to be safe but grr.. I dont like it. But after $10,000 so far , better get used to it haha
negru08 is offline
post #14 of 14 (permalink) Old 05-04-2013, 10:50 AM
I believe that is due to a few things, Primarily the alignment setup and the force of all the air pushing the car down as you drive along. Sure these aren't race cars, but there is still some amount of down force at speed.
Yea can't hurt, hell you can even add a cooler to prolong the life, although I'm sure there's already some sort of mini cooler from the factory.
A good flush might even lighten up the steering a little bit.
  Pontiac G6 Forum > Technical Discussion & Modifications > Problems and Solutions > Steering Lockup Issues & Discussion
Rough idle GoldG6 Problems and Solutions 22 07-19-2013 10:14 PM
Idling rough mzielinski1 Problems and Solutions 8 06-14-2013 02:34 PM
Rough idle jho Problems and Solutions 4 02-12-2013 01:45 PM
Running rough wsboyles315 Problems and Solutions 5 06-13-2012 11:32 AM
Rough shift first > second datacat Problems and Solutions 4 02-26-2009 07:15 AM
