2007 G6 with issues-any more? - Pontiac G6 Forum
post #1 of 8 (permalink) Old 01-25-2014, 10:16 AM Thread Starter
I have a 2007 base 4cyl G6 with 145,000 miles we bought new. Getting the power steering message on the screen and sometimes it works, sometimes it doesn't. If you turn it off and turn it back on it usually works. At a light, sitting still the wheel twitches. Took it to the dealer this morning and they are going to put a column in it for $700. They think the module is OK. I thought 2008 was usually the module? Mine is a late '07 so I would think it more like an '08 than an '05-06? They say I do not qualify for any coverage even under the extensioin of the Service Bulletin. Anybody else with a similar issue on an '07?
markdtn is offline
post #2 of 8 (permalink) Old 02-06-2014, 01:29 PM Thread Starter
Well, the column seems to have fixed it. Nobody else with an '07 having steering issues? Interesting.
markdtn is offline
post #3 of 8 (permalink) Old 03-06-2014, 04:48 PM
I'm having the EXACT same issue with the EXACT same model/engine.
I'm probably going to attempt to fix it this weekend. I wonder how much the column itself costs? Will I need the dealership to do any computer resetting if I install the column myself?
tvanlant is offline
post #4 of 8 (permalink) Old 03-26-2014, 06:27 AM
Anyone?
tvanlant is offline
post #5 of 8 (permalink) Old 04-06-2014, 03:08 PM
http://consumermediallc.files.wordpr...4v153-7510.pdf
Anyone with steering issues, check this out. Scroll down for complete coverage.
09 G6 2.4 Sun & sound package-Preferred package
225/50R17S factory
post #6 of 8 (permalink) Old 04-22-2014, 10:13 AM
So I decided to try the Dorman 905-513 steering angle and torque sensor. Installation was very easy and it fixed the steering wheel twitch and loss of power steering!
Part was $110 from RockAuto.com. No need to buy the entire steering column or have a shop do the labor.
tvanlant is offline
post #7 of 8 (permalink) Old 04-22-2014, 09:04 PM Thread Starter
I thought you needed a Tech 2 to set it after installation?
markdtn is offline
post #8 of 8 (permalink) Old 04-23-2014, 06:48 AM
I did not need to do any programming with mine. During disassembly and reassembly, I was careful not to turn or move any parts or get anything out of alignment. Then I followed Dorman's video exactly on how to replace the sensor.
It started right up and acted as if there was never a problem.
tvanlant is offline
  Pontiac G6 Forum > Technical Discussion & Modifications > Problems and Solutions > Steering Lockup Issues & Discussion
Sensor Issues - 2007 Pontiac G6 sedan 4-cyl richuwo11 Problems and Solutions 10 12-19-2013 01:17 PM
2007 G6 Door Ajar Issues..Alarm Going Off... Franklinstew Problems and Solutions 17 08-26-2011 10:02 PM
Possible G6 issues gtp2006 Problems and Solutions 1 03-01-2010 11:41 PM
A/C Issues '05 G6 nichwarzy General Maintenance 0 09-04-2007 04:35 PM
so... i'm new... here are some issues gobo Handle It! - Suspension, Wheel and Tire Modifications 8 01-15-2006 08:07 PM
