2008 GT -- steering shaft squeals when warm - Pontiac G6 Forum
post #1 of 3 (permalink) Old 10-30-2017, 12:06 AM Thread Starter
I'm the new owner of a 2008 GT convertible with around 115,000 miles. I've noticed a strange issue, though. When the car is warmed up, there's a squeaking noise. However, it doesn't seem to be coming from the power steering pump on the passenger side; it sounds like it's coming from directly in front of me.
Take a listen. It's very loud in this video, louder than it is in person.
It's tough to Google this one, since all the results I see are about the power steering lockups, which the dealer says were all performed.
Also, I'm not sure if this is related, but if I turn the wheel all the way to either side and hold it there, the RPM's will drop, the car clunks and the belt may squeal, and the front end of the car will dip down.
delta is offline
post #2 of 3 (permalink) Old 11-26-2017, 08:58 AM
https://youtu.be/7UTDJt6RVAU
My daughterís car makes a similar squeal. I think it has to do with trying to turn the wheels when the car is not moving and the fact that the car has electric instead of hydraulic power steering. Maybe you should check your tire pressures - if low this might be a contributing factor. PS Most cars wil seem to dip to the side in which you are turning the steering wheel when in a stopped position.
CANADIANG6GT is offline
post #3 of 3 (permalink) Old 11-28-2017, 12:11 AM
Send a message via Yahoo to JoethepainPA73
Mine makes a clicking noise while I turn the wheel. click, click, click...
JoethepainPA73 is offline
  Pontiac G6 Forum > Technical Discussion & Modifications > Problems and Solutions > Steering Lockup Issues & Discussion
How-To: Replace Intermediate Steering Shaft - '08 G6 GXP C0RSA1R HOW-TO 3 04-13-2016 09:49 AM
Intermediate Steering Shaft g6owner_1980 Steering Lockup Issues & Discussion 16 03-22-2013 03:22 PM
2006 pontiac g6 2.4l 105,000 miles p0449 and intermediate steering shaft issue ncdavid2001 Problems and Solutions 13 01-10-2012 10:43 PM
Intermediate Steering Shaft Lower Pinch Bolt je1279 Problems and Solutions 1 11-06-2011 01:41 PM
steering: intermediate shaft 08G63.5 Problems and Solutions 1 12-18-2009 11:20 AM
