I have a 2007 g6 and my check engine light goes on but when we try to pull the codes it says there is an error. Has this happened to anyone else? If so what is the fix before I spend alot of money for them to try to find the issue.
Im not sure what my mechanic(family friend) used. He tried with 2 different computers. Went to auto zone as well and there computer didnt work either. Auto zone said go to the dealership and they would look into it. Went back to my mechanic and he looked at the fuses and anything else in the general area he said it will get costly if I go to the dealership. My mechanic is stumped
Thank you so much Greenman! I'm also having this issue at around 130,000 miles and it's really upsetting after my brake lights & cruise control not working that was recalled but not for my VIN and then replacing my power steering column that was near recall status. At any rate, I hate my g6.
Anyways, this is the closest that I've come to an answer on this thread's issue! Does anyone have any more info on it?
I have a 2007 g6 and my check engine discount hid kits goes on but when we try to pull the codes it says there is an error. Has this happened to anyone else? If so what is the fix before I spend alot of money for them to try to find the issue.
Yes surely it is a problem for many.. You need to scan it and get the right code. If you don't know the way then ask an expert to do it ..
Related Threads
Pontiac G6 Forum
142.8K posts
38.8K members
Since 2004
