I have an 06' 2.4L with an engine light on. Took it into the shop and they found 6 codes:
P0128 - Coolant Thermostat
P0171 - Fuel System too lean - Bank 1
P0106 - MAP or BARO Pressure Circuit Out of Range
P0300 - Engine Misfire (Indicated Cylinder #2)
P0420 - Catalyst efficiency Low - Bank 1
P1174 - Fuel Trim Cylinder Balance - Bank 1
Also, the outlets do not work on the dash.
They topped off the coolant levels and only one code came back:
They switched the coil in the cylinder with another cylinder, but the code still came back up indicating cylinder #2
They have recommended I go to the dealer for more tests, but I don't want to dump a bunch of money there. Does anyone have any ideas what the problem may be? Thanks for your help in advance.
