I bought this car for my 19yr.old grandson its been a good car but it has issues I understand it was a proto type about a month ago front brake pads were put on it that's when all the trouble started.the and light along with the t c svc.eng.light came also I've had the codes read and wipped but soon as you crank it up and put in gear they all come back on could really use some advise
Can I suggest you post the codes as this may give a clue to the issue. If you are certain that changing the pads is related, maybe one of the wheel sensor cables worked loose, has been disconnected or damaged. The sensors send a signal to the ABS / Traction control system so it knows the wheel is turning. That is all I can think of that is in the same area as the brake calipers. The codes may well give more info like which wheel or may indicate something completely different. Good luck with the fix.
