1 - 9 of 9 Posts
I have an 06 g6 gtp. After driving for about 15 mins the temp gauge starts fluctuating between normal and 225 degrees. Usually starts when I slow down. I also have to add coolant every 1-2 days because when it overheats coolant is boiling through overflow hose. Any help would be appreciated.
You have a breach so the system is not able to maintain pressure. You need to find & fix the leak which could be internal or external.
So its probably a bad hose?
The leak could be anywhere in the sealed system. Possibly the reservoir cap itself no longer maintains the seal. They aren't expensive & you might want to just try swapping it out.
AZ may loan out pressure testers, I'm not sure. Or call around & get an idea what they charge to pressure test it. Shouldn't be much.
Try a Youtube search: pressure testing coolant
Token Asian
Hmmm.... There is a bulletin for coolant leak which leads to the crossover gaskets for the 3.5 and 3.9... And I don't think Autozone has the pressure tester conversion to the plastic tanks yet..
Sent from my PC36100 using AutoGuide.Com Free App
Certainly a possibility.
_________________________
Service Information 2006 Pontiac G6 | G6 (VIN Z) Service Manual | Document ID: 2134019
#07-06-02-006A: Coolant Leaking From Engine (Replace Coolant Crossover Pipe Gaskets) - (May 12, 2008)
Subject: Coolant Leaking from Engine (Replace Coolant Crossover Pipe Gaskets)
Models: 2006-2007 Buick Terraza
2006-2007 Chevrolet Impala, Malibu, Monte Carlo, Uplander
2006-2007 Pontiac G6, Montana SV6
2006-2007 Saturn Relay
2007 Saturn AURA
with 3.5L or 3.9L Engine (VINs N, K, I, R, W -- RPOs LZ4, LZE, LZ9, LZ8, LGD)
This bulletin is being revised to update the labor code in the Warranty Information section. Please discard Corporate Bulletin Number 07-06-02-006 (Section 06 -- Engine).
Condition
Some customers may comment on coolant leaking from the engine.
Cause
The gasket located between the coolant crossover pipe and the front of the right (rear side) cylinder head may be leaking.
Correction
Replace the coolant crossover pipe gaskets with current service replacement gaskets, P/Ns 12577704 and 12590668. Before installing the new gaskets, make sure that the mating surfaces on the crossover manifold and cylinder head are completely clean and that NO OIL or OIL RESIDUE exists.
Parts Information
Part Number
Description
Qty
12577704
Gasket, Coolant Crossover Pipe
1
12590668
1
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
J3529
Engine Coolant Crossover Pipe Replacement
Use Published Labor Operation Time
© 2012 General Motors Corporation. All rights reserved.
1 - 9 of 9 Posts
