Hello, I am new to the forum and I need some quality advice. I have an 06 Pontiac G6. I bought a Ready Remote Remote Start and Keyless Entry model number 24923B from Oreilly's for my daughter. I used to work for an emergency vehicle manufacturer and I installed and wired all kinds of equipment in various trucks, but I always had an electrical engineer providing drawings and I could consult with him with any questions. I have no problems finding the right connect points and integrating a wire or harness correctly, but I have never done this on my own at home. If I know where to tie-in the wires that's easy. I don't know whether or not certain wires are necessary to connect, or if there are safety issues if I don't, and things like that.. I have seen plenty of different videos and stuff, but nothing specific to what I am doing. I saw a couple saying I may need an adapter or immobilizer or something.. I have a Directed 4X03 box which looks like the main ignition wires and such, and I also have a box labeled 556U with a 6-pin connection port, and a 3-pin connection port. I just want her to be able to start remotely, and control her locks, anything else would be a bonus. I just wondered if anyone could help me out with some guidance. I have never joined a forum before, ever.. so come on guys, help a brother out! Thanks.
Heya, I hope someone comes along to answer your question, but I think you should give the forum rules a quick read through before posting. This type of post should go in the Problems and Solutions forum channel. The "How-To" channel is specifically for someone who is posting a "how-To" explanation for what to do to accomplish the task. The Problems and Solutions channel is for asking for help and advice when you don't have the answer.
I sincerely hope someone can help you as I am not able, but you will likely get more help if you post it in the correct forum location.
Best of luck,
Nuptup
I appreciate it, seriously. I wouldn’t have any idea if you hadn’t told me. Thanks again
No worries. I only just recently joined myself. I hope someone can help you out. I know I've gotten more than my fair share, so I'm trying to give back to this community. It's great here.
Not wanting to be Debbie Downer, but I do wonder if this is likely to work. The G6 uses a transponder key as part of the security system and sends something like a "fuel continue password" to allow the engine to run. The factory system must be able to simulate or bypass this until the real key is inserted. I am not sure how this unit would manage that. It may be worth a call to the manufacturer to validate compatibility.
