Hey buds, sooo this may be long. I purchased the 95-3303b for my double din JVC headunit, and the aswc-1 for the steering wheel controls... Everything is connected as per the instruction manual. I did connect the 12v constant from the deck, aswc-1 and steering wheel to the metra harness 12v accessory (red) and all the grounds from deck, aswc-1 to the metra harness ground(black). My next step is to split the devices to there own 12 accessory and grounds... I do have the monsoon(amp in the back) does this make the install any different if so how?? Also slight hum at level 1 volume.. because of the grounds??
Also as I was trying to pin point this issue... And found out it was RCA outputs I purchased a new Kenwood double din.. same issue... So I can only some it up to the harness ( red/black/yellow)
And.. with an RCA to aux cable.. would the sound from my phone to amp still be reasonably low(no mirrors shaking lol). But still have sound
Thanks I've never had this issue. Any help is appreciated!!!
