2006 GTP G6 3.9l v6 2 Door Coup
Hey guys need some help. My '06 GTP's trunk won't open. The button or the remote neither one works (the release doesn't even click) when I got the car it didn't come with an accessory key just the ignition key. Not even sure if it had one to begin with. The key lock on the trunk itself is probably damaged as the front part if it has been removed or has been broken off.
Any ideas how I can get into the trunk? Everything online says the seats let down from the trunk.
Any suggestions are GREATLY appreciated!
Discussion Starter · #2 ·
For the record I have tried disconnecting the negative terminal for 5 or 10 minutes.. no luck. Also called a local dealership and they said this model did not have a second accessory key
Post can be locked or closed. Was able to get in. Turns out a pin was stuck in the lock and the ignition key was able to open it
