Has anyone here ran into a problem with heat soak on starter ?
Or no crank no start ?
Not me....I'm really not sure what "heat soak on starter" means. If my starter is not working I blame it on a dead battery, wiring, or a bad starter. But I'm 84 so probably behind times.:)
I mean I crank the car and it starts right up, i drive it to my destination but when I turn it off it won't turn on until it cools down for a few hours. No crank just click.
New battery
New starter
Maybe old wires or exposed wire somewhere idk ?
Checking grounds would be a good start. If you have access to the starter, tapping the starter solenoid with a hammer, for instance, may coax it to start. That would indicate a bad solenoid.
