Hello all,
I have a 2007 Pontiac G6 with a 3.5l v6 in it i am confused to where the crankshaft sensor is anyone able to help me out here?
Also, after replacing the crank sensor do i have to get the ecm flashed?
Any insight on symptoms of a bad crank sensor would be appreciated.
thanks!
Hello all,
thanks!
After replacement of the CKP sensor the CKP system variation learn procedure needs to be done using a tech 2.
On the 3.5l, its located on the firewall side of the block.
http://www.g6ownersclub.com/forum/attachment.php?attachmentid=2625&stc=1&d=1323408008
There's a how-to in the Chiltons for G6.
Without input from the CKP the car will crank but not start. The problem very often is with the harness.
