I have a 2007 G6 GT with a monsoon sound system that Id like to put a new stereo in, preferably a double din touch screen. Now, I know that I will lose the driver information display with this.. but will I maintain my remote start and chimes? Also, what all do I need harness wise? Is it the 250$ kit or the simple single harness? I also have steering wheel controls that I would like to maintain but that will for sure be a separate harness.
Thanks,
Justin
The settings in the dic will stay however they're set with the dic removed. You just can't change them again.
The chimes will still work as they work from a speaker mounted on the back of the speedometer.
You'll need a module for RAP (Retained accessory power) one for OnStar if equipped. And a separate module for the steering wheel controls.
I'm pretty sure the $250 kit is the metra kit designed to retain the DIC. A simple wiring harness should be way cheaper.
I'm not 100% about the monsoon system but I'm sure others will chime in.
