1 - 1 of 1 Posts
Good evening. I have an 07 G6 2.4. When I turn the key to start, the starter clicks 2 or 3 times then stops. I can jump power to the relay pin going to the starter and it will start. I can jump power to the coil of the starter relay and it will start. I am trying to figure out where the coil signal comes from when the ignition switch is turned to start. I feel like it is losing the signal to the relay coil. The car will start and run if I give it 12V to anywhere in the circuit under the hood. Any suggestions?
Thanks
1 - 1 of 1 Posts
