Hello - I've searched high and low regarding this code and this the HF L7Y motor. I can not find a thing regarding just this code showing up. Historically it's been dirty oil. Now, oil is changed and it's still on. However today, while driving, the car felt like it took a jump and is now rough running. It will start, idle hard, it shakes, but once you get t o 45 it's smooth sailing, then again just over 50 it shakes again. Like a broken motor mount type shake. Has a full tank of high octane gas and some injector cleaner in it right now.
I know 0017 is camshaft and crankshaft position sensor and could also be the VVT solenoid. I've been told timing chains, but this car those down twice since I've owned it (bought it brand new) and everything I can find regarding the chains all have multiply codes throw. I am only getting the P0017, every now and then it will say too rich. If I take the gas cap off and put it back on that code clears itself out.
Anyone with any experience with just this code, not this code and others at the same time, but just this one. Could there be sludge in the oil? Should I have the oil treated or replace the VVT Solenoid and then the oil treated?
Any help would be much appreciated it and no it's is not going into low power mode at all. It's just sputtering like a plugged injector or bad plug.
