Hello! I recently changed my oil (about a month or 2 ago) on my 2009 G6 GT 3.5L. It has around 110k miles on it. Sometimes while driving, the oil light will flash on and turn off right away. I know it doesn’t need a change, and whenever I check the oil levels it seems fine. Is this just a censor issue or could I be having a different problem? Thanks!
If I had this problem, the first thing I would do is check the oil pressure switch connectors and ground. These switches are only like $15-$20. If you are having actual oil pressure problems they tend turn on the oil pressure light at low engine speeds.
