I've replaced the bushing 4 times now and it keep popping back off. I'm getting so tired of this car.
Anyone experience this?
Sent from my SM-G950U using Tapatalk
08 convertible
Yes. I did the same. The motor bellcrank ball popped out of the plastic bushing. Even new bushing. I ended up getting a new linkage, AC Delco brand. So far so good.
The way to make sure it's on good is to stall test it. Put it all together, run the wipers and grab a wiper arm and hold it. It should stall the motor without popping the ball out of the socket. It requires a bit of strength but a nornal healthy person can do it. Be safe.
Thank you I'll try that. I was going to drill and tap the bushing/ball stud and put a bolt in it. I'll try a new linkage arm first
Where did you buy the arm? I'm only seeing complete assemblies.
I ended up buying the whole linkage assembly plus a new motor.
08 convertible
Ok, for other readers here is the linkage (transmission) without the motor:
https://www.amazon.com/ACDelco-22711011-Equipment-Windshield-Transmission/dp/B001S82UUG
Also available from Rock Auto or your local GM dealer.
I haven't figured out why an old transmission with all new bushings still pops off the motor ball stud. I'm guessing something about the geometry changes with age and wear.
That is the one I bought. I was thinking originally that I could buy just the smaller linkage arm.
