The accessory outlets require both power and ground to function. If you have a multi-meter you should be able to tell which you are losing and work backwards from there.
Understood. My fear is that it’s some wire break somewhere that would be a total pain in the rear to get to. I might just have to deal with it; sucks though because I can’t charge my phone or use my Bluetooth transmitter.The accessory outlets require both power and ground to function. If you have a multi-meter you should be able to tell which you are losing and work backwards from there.
