1 - 12 of 12 Posts
Hi again,
Wanted to start a fresh thread here with a few troubleshooting questions.
The center brake light is out on my '08 GXP, and I'm wondering how best to troubleshoot it. If the unit is still "live" do I look for a blown fuse or something? Can I use a circuit tester to check the unit/connection?
And - my car came without a keyfob so I bought one online - it is GM licensed/Genuine GM (unless the packaging is counterfeit). I've found some generic programming instructions (which I haven't tried yet), but I've also read that it absolutely has to be done at a GM dealership with specialized equipment. Feedback on this is appreciated.
Thanks everybody!
As I suspected with the keyfob - thanks.
The third brake light is inside the rear window, on top of the panel behind the rear seats. Looks like a bit of a chore to get to it.
yah the flob has to be programed at the dealer, usually bring the service guys in a coffee they will do it quick for free. also if you have a flob that just isn't working, you might need a insert. At my dealer this one 30 bucks and its a new board that goes over the current one after this my flob that didn't work came back better then new. If you need to program a key you can do that your self, once you get them to cut it you can program it, don't let them tell you different . If you need how to let me know ill put up
Well I'm taking the fob to a Chevy dealership tomorrow morning - I'll ask the fee then go from there. It's a brand new fob so it will need the full programming.
Thanks
Ugh!! That's a total pain. I would pull it out and convert it to LED and replace the speakers. Then never bother with it again
I'm pretty sure the brake light in the coupes window is LED which is nice. Mine also has a bunch of dust and dirt in it but it just doesn't look easily accessible to clean.
Discussion Starter #11
Fob
The FOB was successfully programmed at the Chevy dealer yesterday - on 52 bucks - can't complain.
Discussion Starter #12
If that's true then the unit itself is probably working, i guess, meaning the problem is somewhere in the wiring/fuses, etc. which means a lot of troubleshooting. I suppose I could remove the unit and take it in and have it tested - that would at least tell me where I stand.
1 - 12 of 12 Posts
