Working on a 2005 G6 3.5 Cannot get the OBD port to connect. Pulled it out from under the dash and seen a burnt wire spliced in....Cut what I could and spliced together and still not able to connect. No odd symptoms. No lights on the dash. No fuses blown. I'm stumped. Found the diagram below. But there are 3 plugs into the BCM. Need advice
My questions are:
Think it needs a new BCM?
How would I find where on the BCM to test continuity?
Why would previous owner splice into this?
Any help would be greatly appreciated
Hand Finger Electrical wiring Thumb Wrist
Rectangle Slope Font Line Parallel
Super Moderator
I take it you have checked for power on the Red/Wht along with the 10A HVAC fuse. Also worth checking the Grounds. At the BCM I would add electrical grade dielectric grease to the female side of the two connectors and carefully work the connector back and forth to reseat the pins and hopefully ensure a good connection. The BCM / dielectric grease was the subject of a recall to fix some intermittent connection issues. Also check your scan tool works on another vehicle - I have wasted time troubleshooting only to find my OBD II adapter was faulty. Hope this helps.
