1 - 1 of 1 Posts
2007 G6 3.5
P0102 code
I have replaced and check ALL FUSES and relays new mass air flow sensor new pigtail for MAF sensor
I have No reading from the Mass air flow sensor side but I get an accurate reading from the Intake air temp. Its built in the sensor. New Mass air flow sensor new pigtail I have straight wired the black and white wire to 2 grounds. I also straight wired the Yellow MAF signal wire to positive terminal on the fuse box. Still nothing. Anyone gone thru all the checks and still dont have power. All Iv seen is the black and white wire being talked about and i have already straight wired that. Anyone have a wiring diagram to the ecm?
1 - 1 of 1 Posts
