1 - 10 of 10 Posts
Before buying winter tires, I would like to know if a person can put on a different size tire.
I have 225/50R17 on it right now. Can I go with a tire like a 225/60R16, for example?
If so, anybody have any advise on where I guy can get an extra set of rims for the 16 inch tires?
Thanks,
Gerald
The best thing to do would be to get a set of 16" steel rims.
Right now you have the 225/50/17, the standard size of the base G6 with 16" rims is a 215/60/16, which is a 1.15% difference in diameter compared to what you have now. I decided to go with 205/60/16's because the diameter difference is only 0.66%, they are also slightly cheaper.
With the 205/60/16's on, the GPS and the spedo are exactly the same to atleast 90mph (145kmh ish).
Either size would be good, most companies seem to reccomend staying under +/- 3% diameter difference. The larger +/- the size difference, the more the spedo will be off of how fast you are actually going.
Here's what I use to compare sizes
May I ask why you want to go down to a 16" tire? I personally put Continental Extremecontact DWS 225-50-17's on my fiance's 08 GT. I am very happy with the grip and ride of the tire wet and dry, but the sidewall on the tires are a little on the soft side.
I was able to get a set 4 of Michelin X-Ice with 2 seasons left on them with 4 steel rims for $250.
Looking at it now, prob should have gotten 17's so I have the option to get bigger rotors/calipers, but it was a great deal.
· Premium Member
with the right rims im sure you could do 17
1 - 10 of 10 Posts
