Just got me a 2008 G6 V6. When driving it,it shudders (the only way i can explain it), a short jerking action. Not sure what to do or what the problem is...any ideas?
Well it seems to effect it mostly when I'm accelerating...its a engine shudder is the best I can describe it. Almost like a hiccuping as if the car isn't getting enough gas.
The only thing I can suggest would be:
1)try some fuel injector cleaner maybe you got some bad gas some where.
2)try check spark plugs and wires. take the wires off and look to see if the is any corrosion.
3) Has it been doing it all the time? b/c i had a jeep that only did it when there was a lot of moisture in the air. I think the water was getting the spark plugs or some thing.
hope this helps, did the best i could.
